05-23-2011, 11:37 AM | #1 |
Will this wheel/tire combo work
I'm thinking of putting 237/75 R17s on my 65 C10 fleet that has a 2.5 inch drop on the front and 3 inches on the rear. The tires are 30.9X8 inches. I did a search and found alot of combos but not this one,anyone using this size tire or a combo that is this diameter?
Thanks |
05-23-2011, 11:54 AM | #2 |
Re: Will this wheel/tire combo work
Man there are so many variables that this is a loaded question, what frontend
stock, later model with 5 lug and discs------what rear end? stock, later 70's, brakes and lug pattern ??? this is why no one responded its a little complicated and if the truck is not bone stock the question can only be answered by you...Kieth what wheels, what offset, front and rear will probably be different I do not think u will have trouble with the tire size, just what wheel and what offset. Last edited by kieth; 05-23-2011 at 11:57 AM. |
05-23-2011, 12:44 PM | #3 |
OK a little more info.
Front - Drop spendles with disk brakes and a 5 on 5in bolt pattern power steering box from a 72 C10 Rear - Stock with a 5 bolt replacment axiles. Wheels - 17 X 8 inch with 4.5 inch back spacing and 0 offset |
05-23-2011, 04:22 PM | #4 |
I have a pair of 275/55R17 on the front with a 4.5 inch drop and they fit. So I would say yes. But I might be wrong.
