Old 05-23-2011, 11:43 AM   #1
veinbar
veinbar's Avatar
12 bolt to 10 bolt swap?
I have a GM 12 bolt 3.08 rear in my '79 Bonanza. Can this be swapped out with a GM 10 bolt off of a '78 chevy sport van? The 12 bolt I have is in serious need of an overhaul, or I can swap to a free and healthy 10 bolt rear. Is this possible? What problems will I run into?
veinbar is offline   Reply With Quote
Old 05-23-2011, 11:59 AM   #2
ont_guy_38
ont_guy_38's Avatar
Re: 12 bolt to 10 bolt swap?
Not sure if the width is the same but if it is and everything else is the same (shock mount , spring perches widths) then the only other thing might be a new ujoint .
ont_guy_38 is offline   Reply With Quote
Old 05-23-2011, 09:02 PM   #3
Pyrotechnic
Pyrotechnic's Avatar
My dad researched this some time ago and I believe the conclusion was that the spring perches were a different width and it was not bolt in. Not sure about track width though.
The correct rear ends for these trucks are pretty common and keep in mind that a Suburban rear will work too. You can probably find one that is in good enough shape to run for a decent price.
Of course if you have a welder and some time to relocate the spring perches and shock mounts, then the free 10 bolt is probably the cheapest route. Especially if it has some desirable gears or a posi. Just make sure the track width will work under the truck.
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
