05-23-2011, 01:48 PM | #1 |
oil pan question
so will the stock oil pan on a fbody ls1 work on a 72 2wd? I have searched and read many post on this and Im still a little confused.
1972 C-10 short bed, 2wd, 350(ls1 coming soon) 1969 camaro ss, 496 stoker, 4sp 2009 crew cab,duramax 2500hd 4x4, lifted (sold) 2008 Daytona Charger, Hemi Orange, 07 C6 Z06 2005 suburban, 2002 grand prix gt 2005 grizzly, 2004 R1 |
05-23-2011, 02:37 PM | #2 |
1965 Chevy C10, 2005 4.8L/4l60
Re: oil pan question
stock truck pan will work just fine, is it lowered and if so, how much?
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! Last edited by Clyde65; 05-23-2011 at 02:37 PM. |
05-23-2011, 03:11 PM | #3 |
its stock in the front and lowered 2 inches in the back, I just didnt want to buy a new pan if i didnt need it
05-23-2011, 03:17 PM | #4 |
if you plan on lowering it, like a 4/6 eventually or even lower, then yes it would be a good idea to do it now. If your not going to do that, no way no how etc.etc, then a truck pan will be fine, my truck pan sits about 1" below the cross member.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
05-23-2011, 04:16 PM | #5 |
meowMEOWmeowMEOW
Clyde, he's referencing the F-body pan if I read it right.
F-Body is 5 1/2" deep and the truck is 8 1/2" deep. He should be fine with the depth on the fbody pan as long as the shape clears the crossmember. I have the LH8 pan, and its about 3/4 LOWER than the skid plate/xmember. I'm lowered 4/6 (maybe a bit more) and its fine, but a bit nerve racking on speedbumps or big dips.
05-23-2011, 05:06 PM | #6 |
Yea Br3, I figured that but I was just currious if he was planning on lowering it more, if not, then why buy the fbody pan? stick with the truck pan and he is still good to go.
If he plans on lowering it alot, then the fbody or the LH8 pan would be the option.
05-23-2011, 11:52 PM | #7 |
If I'm reading this right, his sig says 'ls1 coming soon' so I would assume he's getting an ls1 out of an F-body. I think that pan might be hard to use in a truck because the sump part of the pan extends too far forward. You would either have to move the engine back further or maybe try to raise it up to clear the crossmember. The Hummer pan or truck pan would be easier to use, although they do hang about an inch below the crossmember. But even if the pan is higher than the crossmember, it's still not completely safe from every road hazzard, my Nova the pan is higher than the crossmember, and I have a broken oil pan to prove it.
05-24-2011, 06:34 AM | #8 |
I have a complete ls1 out of a 00 formula, I was wondering if the stock pan that is already on the engine would work, or if I needed to buy the lh8 pan. I havent started the swap yet, so i was trying to see if i need to change the oil pan or if the stock one would work. I have no plans of lowering the truck. Another reason I was asking is that I have a guy that is wanting to buy the fbody pan if I take it off. I appreciate everyones help. Sounds like I would be better off to go ahead and put the Lh8 on it.
05-24-2011, 09:11 AM | #9 |
I would go ahead and sell the F-body pan, they will bring between$ 150 and$ 200.. and a truck pan can be picked up for about$ 50. It would save you some on your swap, and most likley be easier.
Posted via Mobile Device |
05-24-2011, 10:06 AM | #10 |
meowMEOWmeowMEOW
Get the swap pan/lh8 pan. The truck pan works, but the larger size makes fitment a little tighter. If your putting the engine and trans in together, the extra clearance on the front of the pan is a godsend when maneuvering around the core support.
05-24-2011, 11:35 AM | #11 |
I think I will get the lh8, my oil pan is the fbody one
05-24-2011, 05:44 PM | #12 |
Truck and auto performance nut
My pan is the stock LY6 pan and fits good other then hanging down below the crossmember a bit...as do the headers
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
05-25-2011, 03:36 PM | #13 |
It all depends on the motor mounts you use. If you go with ECE mounts, the Fbody will not work. You'll need to use the CTsV pan or the H8 pan. If you go with Street and performance or CPP style mounts the Fbody pan should work with no problem.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
05-26-2011, 10:03 AM | #14 |
I have the truck pan and mine is lowered 3/4 with springs.
check out paceperformance swap kit, i think its the Hummer pan but everything is like $150.
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap |
05-26-2011, 12:34 PM | #15 |
meowMEOWmeowMEOW
ya, its the hummer H3/LH8 pan with the pickup tube and windage tray etc. Not bad for the price.
05-27-2011, 12:10 AM | #16 |
If you must use the stock truck pan, put a skid plate on as well.
05-27-2011, 11:37 AM | #17 |
plan on getting a different pan for mine when I get the new DT big tube headers....then everything will be within the frame rails, with nothing hanging down
