67-71 vs 72 Doors
From what I understand, there was a change made to the 72 doors. Is that correct? How would I tell if all I'm looking at are the doors?
TIA Mike |
Moderator
![]() Join Date: May 2007
Re: 67-71 vs 72 Doors
There is a reinforecement screw just below the vent windows, on the inside.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
#3 | |
1968 chevy lwb, getting ready to join forces with the 70 gmc 1970 gmc swb, getting ready to be a 68 chevy swb 1971 gmc lwb 2500 2wd Sierra Grande 1988 chevy 1-ton crew cab 2wd waiting for a 12v cummins |
So there wouldn't be any fitting issues in case that's all I can find? Thanks all for the quick responses!
Posted via Mobile Device |
It's a catastrophic success.
![]() Join Date: Jan 2003
Window crank shafts are longer due to the thicker inner door panels.
454 MAKES IT ROAR
Sneaky is correct, I found this out the hard way, its something that gets overlooked or simply not realized.
One day when I get to do my "forever in the pipeline" frame off, I plan on swapping for the later doors, it's a pain how the outer skin has pulled away from the inner on mine, looks ugly, but on a more practical note the outer window seal doesn't even touch the window. This was a much needed improvment to stop that flexing between the inner & outer skins.
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger Last edited by eightbanger; 05-24-2011 at 04:48 AM. |
Thanks all for the replies!!!
I found me a door that I'm hoping is still available this Saturday so I can go pick it up. It is a 72, but I'm okay with the differences mentioned ![]() Thanks again. |
Moderator
If you need to go with earlier door panels and do not want them to stick out, simply change the window regulator to a 67-71. The crank is shorter and will correct the problem. You would need to drill holes to attach the older panels, as the 72's attached with plastic clips.
Eightbanger is correct, the reinforcement screw keeps the glass sandwiched in the door frame, making for a much better seal than previous years.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul Last edited by leddzepp; 05-25-2011 at 02:46 AM. |
