Old 05-24-2011, 02:03 AM   #1
taank
Pictures needed of wooden truck floors!
In particular the bed floor supports. What is the correct area a step side should match up to the cab? Do the tall bed supports go in the front back or middle? Im working with a previous installed wood bed kit that never really did fit right. Is there a bushing or mount that goes between the bed and frame bolts?
taank is offline   Reply With Quote
Old 05-24-2011, 06:48 AM   #2
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
Re: Pictures needed of wooden truck floors!
Here's a pic of mine without the box on. The thin strip setting on the tire goes about at the rear tire area.
There is a square rubber pad that goes at each bolt location between the frame and cross sill.
Hope this helps...
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 05-24-2011, 10:11 AM   #3
Tim R
That thin strip on every step bed I have seen and even on mine goes about 8 inch behind the second main bed support from the front of the truck . Its loacation is marked by the holes in the angle strip on the passenger lower angle strip thats welded to the bed side. On a couple of frames I have even seen where that small support strip has even rubbed groves in the main frame of the truck from having a lot of weight in the bed of the truck.
Tim R is offline   Reply With Quote
Old 05-24-2011, 01:29 PM   #4
SC C-10
SC C-10's Avatar
Here is mine before it was mounted with the cross supports already installed. Hope this helps.
1969 C-10 short step
1981 CJ7
2017 Ram 2500 Laramie 4X4
1939 Cadillac LaSalle sedan
1950 Allis Chalmers B
1998 Bullet 21 XD 300 Merc/water hot rod
SC C-10 is offline   Reply With Quote
Old 05-24-2011, 09:03 PM   #5
Ole Greenie
Ole Greenie's Avatar
This is one of Trex... a wood decking composite. Should outlast the truck!
John Paap
Ole Greenie
Hagerstown, MD
My Mistress
70 CST Short/Step
LS 5.3/4L65E
New motor install Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=667773
Ole Greenie is offline   Reply With Quote
