been here longer than Liz
The driver's seat belt in the '89 Jimmy rolled up and locked in place. I can't get it to but at all. Any tricks to getting it loose? Wasn't real thrilled with driving halfway to work this morning with no belt.
~Greg~ Mac's Garage '87 SWB 6/8 drop "Piso" '08 CCSB Silverado DD the departed '89 GMC K5 Jimmy 4x4 "Rusty Nuts" '77 Chevy K5 Blazer 2wd '83 Chevy stepside "You get what you pay for" - Mike 'swervin ervin' Ervin |
Re: seat belt help
For safetys sake maybe just replace it? LMC truck parts?
Re: seat belt help
I'll be doing that rayfin. Just hoped there might be a known issue I could deal with at lunch so I could have a belt for the drive home.
Slots go on anything!
Re: seat belt help
The retractor is made similar to a come along. If you take the cover off, you might be able to unlock it that way, and get the belt unrolled.
1974 Jimmy- 5.3/4L80e/NP241 |
Re: seat belt help
On my '87, one of the belts locks all the time. I reach under the cover and push on a flat plate that runs across the spool. Its loose and moves easily. When I push up, the belt unwinds. But then it locks when I release it. Similar to how the retactors lock when you pull them all the way out to install kiddie seats.
Good luck! Posted via Mobile Device
'87 R30 Crew Cab Dually It's 11 PM, do you know where your IAC pintle is? |
78K & 79C Jimmys
Re: seat belt help
in the front door jamb is the release, the white button(by door catch pin)
see if that is working freely (spring in there jams or breaks)
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
Re: seat belt help
Oh... I wasn't trying to be a smart*ss I just wanted you to be safe. Did you have any luck?
Re: seat belt help
None. I got the cover off enough to look at the bottom, there was nothing I could push on as Hulk suggested. Just the bent plate that bolts to the cab and has a rivet holding the cover in place.
Also tried the release like motornut said, and that moves freely but did nothing to release the belt. I'm going to order new belts today. I'll drive the truck until I can get these replaced.
Re: seat belt help
Where are you getting your new belts from? Can we get a write up about them? I need one belt, but If I replace them I want them to fit and look like factory or I'll just keep mine since it's just cosmetic.
Re: seat belt help
Well I thought LMC, but all they list for my 89 is a lap belt. Once I find replacement tri-points I'll let you know. But yeah, I can take photos and do a write up.
Re: seat belt help
If you can't find a new one, you might check this out: http://www.ssnake-oyl.com/mm5/merchant.mvc
Re: seat belt help
I also tried manipulating the weight last night, still no dice. Next step is to remove them and try to clean.
#13 |
Re: seat belt help
Since you are not using your belt, you might as well unbolt it and have a look see. Be careful with the bolts - the threads and threaded holes are a little different than most. I managed to strip one in my 76. Because of the cramped quarters, make sure you have your wrench(es) straight and take your time turning out/in. A little grease on the reinstall would be a good idea.
#14 |
78K & 79C Jimmys
Re: seat belt help
if you can get a wire brush on a drill to the bottom/underside of the bolt might help to loosen
or a quick sand blast
#15 |
Re: seat belt help
I managed to take the winder off the post yesterday. Took me a while to track down a T55 torx bit to do the job. I didn't have to drill out the rivet holding the plastic cover in place, the access plate got me to where I wanted to be.
It wasn't the weight hanger that was causing the problem, it was the reel catch (term?). I fiddled with it for a second and got the belt working. Cleaned out what I could reach then reinstalled. The belt seems to be working fine now. Afterwards I saw a small brass C clip on the floor. Took the belt back off but couldn't find where it goes to. Hopefully nothing too important...
#16 |
Getting Old; Going Broke
Re: seat belt help
Save the clip, you'll probably figure out later where it goes.
![]() Only C clip I recall is on the main roller pin that everything winds up on, but it was very visible, I think. Been a while since I was inside mine.
Why is every used 350 sbc out of a corvette? There's only two things that excite a man, expensive toys and real expensive toys. VEGETARIAN: That's an old Indian word meaning "I don't hunt so good." When the going gets tough, switch to power tools. |
