Black Iron Pipe?
I'm trying to figure out how to mount my top bag mounts and I saw some black iron pipe at HD that would seem to do well. Can anyone tell me if this stuff is strong enough to put into a suspension?? If anyone has any other advise about some type of strong pipe, I'm all ears. I have a step notch that I now need to mount some bag brackets off of, need to use circular pipe that is strong. Thanks.
----------------------------------------- My 67 c10 Thread. http://67-72chevytrucks.com/vboard/s...d.php?t=409192 |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: Black Iron Pipe?
You need DOM tubing.
Contact www.*******************. http://*******************/catalog/steel-tubing
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 05-24-2011 at 02:03 PM. |
I've read a little bit and I think that Black iron pipe is strong enough. Hell, I've read where people built little rat rods and framed it out of it! We will see. Thanks lolife for the reply. Think I will just try it and test it out the best way I can. We will see!
Black iron pipe is not structural steel (Home Depot/Lowes stuff).
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 05-25-2011 at 12:23 AM. |
You're getting black iron confused with pipe - A lot of offroaders build stuff out of Schedule 40 pipe - here's some more info:
Poop Pipe Thread Don't use black pipe - you'll hurt someone. If you could promise us it would only be yourself and not an innocent bystander when your sh!t breaks - that's one thing. Don't put others' lives on the line. ![]() |
The term "Black Iron Pipe" means almost nothing to most home builders. Truth is there are a lot of different grades of pipe. Some are good for structural applications and some are not. Some are weldable, some are not. You don't necessarily have to use DOM, but you do need a weldable quality pipe with decent elongation and tensile / yield strength.
How do you know what to use? The pipe should have ASTM numbers stenciled on the side of it. Should be something like "ASTM A-53-B" or "ASTM A-106-B" or "ASTM A-106-C". Look at some long lengths of the pipe, reply to this thread as to what is stenciled and I will look it up for you. If it doesn't have the specification written on it, don't use. Hope this helps. Last edited by lakeroadster; 05-24-2011 at 08:55 PM. |
No stamps but out has-c-40 PLL1 HFW TESTED 700/lb/IN2. Any idea what that means? I thought this was schedule 40 our pipe but not so sure now...that's for the advice guys. Anyone know what those making mean?
#8 | |
Is the pipe you bought 1" pipe? 1 = 1" pipeThere should be a specification though. You need more information to really know what you have. Last edited by lakeroadster; 05-24-2011 at 09:28 PM. |
Yes is 1", trying to get son to sleep, will pull the stickers and check in a few.
BMW & ASE Master Certified
im sure rat rods were built from that cheap pipe... the concept for most rat rods is "cheap"... cheaper than these trucks...
clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
Here is what I found
Astm a-53-a/api5l Erw 1.315/a33 not sure about the a33 kinda scratched. Posted via Mobile Device
Oh, it's made in mexico, at least it's not china!
#13 |
A guy with a truck
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
#14 |
Don't use it. A-53-A is not for structural use. If it was A-53-B I would use it.
In the fab shop I worked at we would use A-53 Grade A for stuff like handrailing. Last edited by lakeroadster; 05-25-2011 at 08:47 AM. |
#15 |
Thanks lakers for the help. Im going to try to find some dom steele I guess. So hard to find around here though...
#16 |
Call Ryerson Steel, they have a location in Mobile: http://www.ryerson.com/gulfcoast/
Ask them if the sell to walk in customers, or if they don't, ask them for the name of one of their local customers that does. And their on-line stock list is second to none. Check it out here: http://www.ryerson.com/stocklist/l-843.html Good luck and Happy Trails! Last edited by lakeroadster; 05-25-2011 at 08:07 PM. |
#17 |
laker I called them but they said they don't have anything. I'm gonna try these off road shops in see if they have any scrap. Thanks for all your help!
#18 |
Found some schedule 80...that should be strong enough right?
#19 |
Nevermind, found some DOM, 6ft for $55, can't really put a price on safety!
