Old 03-30-2003, 12:34 AM   #1
KEH
Better late than never
KEH's Avatar
Brake booster vacuum source
I just added a brake booster. Where should I hook up the vacuum hose? The 2 sources at the carb base are used for the distributer advance, and pcv valve. Do I need a T or is there another place to hookup. Thanks.
Ken
1970 C/10 SWB Stepside
KEH is offline   Reply With Quote
Old 03-30-2003, 12:42 AM   #2
gr8scott51
gr8scott51's Avatar
You can buy an carb spacer block with a vacuum port.
Silence is golden, duct tape is silver. - Scott
gr8scott51 is offline   Reply With Quote
Old 03-30-2003, 01:05 AM   #3
cdowns
cdowns's Avatar
directly from the manifold. on the 350 there's a port you can use that is directly in back of the carb and in front of the distributor. i'm not familar with 6cyl so i dont know about that
Old 03-30-2003, 01:09 AM   #4
KEH
KEH's Avatar
The port on the back up the carb is where the pcv valve is plugged in. Do most just T off of that?
Old 03-30-2003, 01:58 AM   #5
cdowns
cdowns's Avatar
NO NOT OFF THE CARB OFF THE MANIFOLD!!
Old 03-30-2003, 06:35 AM   #6
Project1970
14.1 @ 96MPH
Project1970's Avatar
Anywhere you're getting full manifold vacuum would be fine. If there's not a port on the manifold directly (in which case I'd be slightly surprised if it's a V8) you should be fine T'ing in on the one on the back of the carb.
Project1970 - LS1 Swap Complete!
Project1970 is offline   Reply With Quote
Old 03-30-2003, 10:18 AM   #7
Blue Beard
Blue Beard's Avatar
Mine comes off the manifold................
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 03-30-2003, 12:13 PM   #8
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
There is nothign wrong with going from the carb.
On the intake there should be a plug somewhere with a 1/2 inch (or so) pipe plug, get a fitting for that if you have no carb provisions.
Old 03-30-2003, 05:55 PM   #9
KEH
KEH's Avatar
Sorry cdowns. It would help if I would have read your post closer. Yes I do have the manifold plug you described. On my way to get a fitting.
Thanks for the help guys.
Old 03-30-2003, 06:14 PM   #10
racedvl
racedvl's Avatar
I say go to the junkyard and find the "t" behind the carb, on a car/truck with power brakes. Install that into your manifold.
racedvl is offline   Reply With Quote
