Under Bed gas filler neck relocation????
Hi, just wondering if anyone could help me out. I just purchased a 67 c10 and the previous owner put the 21 gallon tank underneath the bed. Except he made an area in the bed to lift up and left the filler hose uncapped flopping around.
Im about to redo the entire wood floor and want to relocate the filler neck in a proper location with the right cap and finish it out properly. Just wondering what everyone did and filler neck relocation and gas cap they used. Pictures would be great. Thanks in advance. |
![]() Join Date: Oct 2009
Re: Under Bed gas filler neck relocation????
Hey romes20,
![]() Again, there is TONS of great info here. ![]() Justin
Justin 71' C10 SWB 00' Dakota R/T 05' Z-71 Silverado 16' Z-71 Silverado Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=376904 |
Check out post #3 "Filler Neck Options" on this thread..... http://67-72chevytrucks.com/vboard/s...&highlight=gas
thanks for the info
Its a Truck Thing......
I put mine in the wheel well, looks good, but if you are going to drop it you have to make some changes.
Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time |
71meangreen, mine is located in the wheel well now and I would like to lower it 3 inches in the front and 5 in the rear. What type of changes are you refering to? or it sounds like I screwed up already.
Thanks |
sorry about that. 67 short bed stepside.
According to where your neck and lines are, dropping it more could result in the lines hitting the tire... Mine is a fleetside and the way i did mine, i couldn't drop it more than a couple of inches without worry.
Smitty
thanks 71meangreenc10
Smitty you wouldnt happen to have a pic of where you located yours on the wheel well would you?
and what cap are you using?? Last edited by romes20; 05-27-2011 at 12:12 PM. |
Hi looking for someone in the Edmonton Alberta Canada area who has installed a rear tank and a side filler on a 67 fleet side . Would appreciate any help and pictures of how to run filler hose.
#13 |
I installed a round gas door from a late 90's chevy truck. I have relocated the gas tank to the rear. With the tank I installed I needed to notch the top of the frame for the filler tube to attach to the side mount of the gas tank.
Hope these photos help. ![]() ![]() ![]() ![]() ![]() ![]() Notch before welding. ![]() ![]()
1970 GMC 2500 700R Trans RideTech 4 link rear suspension - Air Bagged on all four corners 350 SBC 300hp Weiand Supercharger FiTech EFI |
