Old 05-24-2011, 10:29 PM   #1
05Gibbs
05Gibbs's Avatar
starter sticking?
i went to start my 83 shortwide today and the starter stayed going after i turend the truck off and even pulled the key out. i had to go unhook the batt. would that be the ignintion switch or the lock and tumbler thingy? im kinda not sure where to start on this
05Gibbs is offline   Reply With Quote
Old 05-24-2011, 10:45 PM   #2
rayfinseats
Re: starter sticking?
How about the "s" terminal wire touching the battery cable at the starter? I have never had that happen before.
rayfinseats is offline   Reply With Quote
Old 05-24-2011, 11:42 PM   #3
05Gibbs
05Gibbs's Avatar
its not doing it all the time. and i can mess with the key a few times after i unhook the batt and it will work like it should about half the time
Old 05-24-2011, 11:57 PM   #4
Phillip Pennartz
I wonder if it may have a weak or broken spring in the solenoid?
Phillip Pennartz is offline   Reply With Quote
Old 05-25-2011, 01:22 AM   #5
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
When I had problems with my tumbler and key my truck wouldn't want to shut off or start because it was all worn out inside. I would start there first. I needed a new column so replaced the whole thing!
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
