Old 05-25-2011, 07:29 AM   #1
big10ratrod77
big10ratrod77's Avatar
chevy 250 with poor cold performance
hey guys ill be putting tags on my 79 this week and it still dosent run perfect. the truck has a 250 with pair smog injection, 3 on the tree, and 3.08's. the truck cranks up perfect every time but if it has been ideling for 3-5 mins the truck will not take off to save your life it will just choke off, but when it has been running for 15-20 mins it will take off reasonably good. ive tryed a bunch of stuff to get it fixed, ive replaced the weights and springs in the distributor, new cap and rotor, rebuilt the carb(rochchester verijet), installed a new heat riser, set the timming, bypassed all vaccume controled emissions devices, and attempted to adjust the carb. have eny of yall had this same problem?
77 chevy BIG 10 350/sm465/12bolt w 3.73 bout 240 horse power NO power steerin
79 chevy 1/2 ton 250/three on the tree/3.08s soon to get built 250/floor shift conversion/3.08s
81 mercedes 300d 25 MPG
77 chevy BIG DOOLEY 454/sm-465/14 bolt 4.10s "fully loaded"
73 plymouth duster 225 slant six/230 3 speed/8 1/4 trying to acheve 300 horse six http://www.cardomain.com/ride/3135091
'77 chevy trucks. built to stay tough.
life is short build a hot rod
big10ratrod77 is offline   Reply With Quote
Old 05-25-2011, 07:55 AM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: chevy 250 with poor cold performance
sounds like the electric choke may be bad or need adjustment
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 05-25-2011, 08:41 AM   #3
1LowToy
Try adjusting the choke pull off linkage, to make it pull off less. If it's like mine it runs very lean. My next step is to drill out ever so slightly the idle jet port, when I find another unmolested carburator to experiment with. Plugging off the emissions equipment will only cause you more headaches. There is a vacuum hose leading from the carb the driver's side of the valve cover right above the exhaust that can get burnt through. Big lean spot potential.
1LowToy is offline   Reply With Quote
Old 05-25-2011, 02:51 PM   #4
dswancutt
I may be wrong, but I think GM chose to run the choke off the oil pressure switch for that year. Something to think about.
My 76 with the non intergral head is a cold blooded beast and I can remember how my or my uncles 79's ran when cold.
dswancutt is offline   Reply With Quote
