05-25-2011, 09:30 AM | #1 |
Drop Spindle Question
I have a 66 Swb Stepside with a factory drums and Im lookin to drop it 2.5" with spindles. If I convert to disk brakes via coversion kit will the drop spindles have to be changed to coop with the disks?
Thanks in advance. Posted via Mobile Device |
05-25-2011, 10:25 AM | #2 |
Re: Drop Spindle Question
Can you get drop spindles for drum brakes? When I looked a while ago (for a friends truck) all I came up with was spindles that took disks. I probably didn't look at the right sites though.
1961 GMC. Start date 1/20/2011 Past projects: 1958 Fleetliner 14ft Runabout 1966 Caprice 2dr 1970 VW Squareback |
05-25-2011, 11:49 AM | #3 |
i personally have only found drop spindles for the disc 5 and 6 lug but not for drums
Due to financial constraints, the light at the end of the tunnel will be shut off until further notice |
05-25-2011, 12:12 PM | #4 |
Thats right. What exactly Are my options when lowering?
Springs, and? |
05-25-2011, 12:23 PM | #5 |
Spindle kits with brakes, or springs is all I can think of.
05-25-2011, 01:03 PM | #6 |
Are there any tutorials on how to swap front or rear ends on this site?
I've found this for disk Conversions and im hoping somthing similar's somewhere in here for front entire swaps. http://67-72chevytrucks.com/vboard/s...t=lug+steelies Last edited by First66; 05-25-2011 at 01:04 PM. Reason: Forgot to add link. |
05-25-2011, 01:06 PM | #7 |
Rollin' Old Skool
yep, you can get drop spindles if you convert to disc brakes...factory options you could use would be from a '71-72 or the '73-87, or you can purchase aftermarket kits...if you keep drums, your only option will be to change springs
05-25-2011, 01:09 PM | #8 | |
Rollin' Old Skool
