05-25-2011, 09:57 PM | #1 |
Question about harmonic balancer on a 250
I do apologize in advance on this question, I know there has been other posts in regards to it but I just want to make sure. On a 250 engine when mounting the harmonic balancer is there suppose to be a retaining bolt at the end of the crankshaft? I heard yes and no, so i want to make sure, I know when I got the motor there wasn't one on there, looked at others and the same but then some do. I looked at the crankshaft seems as the previous owner tried to tap one in and failed. Just want to make sure I am not missing something here don't want this balancer flying off when I am down the road, That would be a site to see, lol. I know every other engine I have worked on has had a retaining bolt for that purpose and hand cranking the engine, so anyways I would like to get some inputs from you guys Many Thanks
Dennis N. USN Ret. Patriotism is your conviction that this country is superior to all other countries because you were born in it. |
05-26-2011, 08:15 AM | #2 |
Re: Question about harmonic balancer on a 250
Many 6 cyl. and early 283 327 engines didnt have a retaining bolt .. the only time I would worry about it is if you plan on racing it .. i lost one off a 327 half way down the track years ago .. since I do crankshaft work /grinding and repair I offer the service to customers so that they dont have any reservations about it later.... The 235/261 dont have it either... As the factory started placing pulleys farther out from the balancer I think it became a problem and they went to a bolt ... if you can drill and tap it with out a problem and for a peace of mind then do it and you wont think about it later .... you can go to a 1/2 inch bolt if the previous owner has messed up the threads or didnt get it drilled or tapped correctly...
05-26-2011, 08:40 AM | #3 |
Thank you awbrown for the reply and the information. I kinda figured it was set up that way but just wanted to make sure, due it was the first time I encountered one with out a retaining bolt. Thanks again
