Old 05-25-2011, 10:41 PM   #1
LeftCoast32
Custom Builder
LeftCoast32's Avatar
17X9 Steel Wheels
These are the Steel Wheels I had made up in 17X9 with 5" of backspace. They have to clear a D60 and 14B FF with Disc Brake Conversion. They fit like a glove over the brakes and steering.
They are a little dusty from setting around in the garage.
LeftCoast32 is offline   Reply With Quote
Old 05-26-2011, 06:03 PM   #2
LeftCoast32
Custom Builder
Re: 17X9 Steel Wheels
The plan is to run the real long chrome lugs front and rear.
I am going to run a set of real thin Stainless Steel Trim Rings.
The Dana 60 Mile Marker Hubs are Polished Stainless Steel.
The 14Bolt FF will have Polished Stainless Steel Axle Shaft Bolts.
Should look pretty good when finished.
Old 05-26-2011, 06:09 PM   #3
jimmydean
jimmydean's Avatar
Nice, where did you have them made?
There used to be a shop around here that would make custom steel wheels, but they went under a while back.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 05-26-2011, 06:46 PM   #4
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Interesting, I made a set of 17" 6 bolt pattern, modified from the stock 17.5" that was available in our series. In your 8 bolt pattern you could get up to a 19.5" wheel optioned.
Old 05-26-2011, 07:24 PM   #5
LeftCoast32
Custom Builder
I had them made by a company that supplies all the outer hoops and inner wheel centers to all the companies that sell steel wheels. They dont deal direct with the public at all, sorry.
I went with the 17's because of all the tire choices. I will be running 37/12.50x17 BFG Mud Terrain KM2's.
