Old 05-26-2011, 01:04 AM   #1
alexr421
alexr421's Avatar
cpp tilt
have any of you guys bought the 4 speed aftermarket tilt column from cpp?? and can you tell me if it is ok as far as quality goes.. im putting a t56 im my 67 and considering one from them..i dont much like the flaming river or ididit..i kind of like it to look some what factory on the inside..thanks for any imput..! alex
alexr421 is offline   Reply With Quote
Old 05-26-2011, 05:02 AM   #2
oldspowered67C10
Re: cpp tilt
I'm not sure if were talking about the same thing but I just bought the 67-72 tilt/auto trans one this past weekend. Haven't installed it yet(will this weekend) but so far it looks OK. Definitely not as nice as a ididit or flaming river but when you look at all the features it has(illuminated range indicator,tilt,powder coated, 3 and 4 speed indicator inserts) and the fact that it comes with all the knobs/handles, all the seals and the cancel cam/horn ring and spring for less than half the price I figured it was worth a shot. I'll let you know how well it fits this weekend.
oldspowered67C10 is offline   Reply With Quote
Old 05-26-2011, 06:01 AM   #3
alexr421
alexr421's Avatar
Re: cpp tilt
well it should be the same thing..but im going to be getting the 4 speed version.. the one im talking about looks like a factory set up..just aftermarket..they have rebuilt originals but good greif are they high dollar..just makes me think there repop ones could be cheap..yes, please let me know what you think..thanks, alex
Old 05-26-2011, 07:15 AM   #4
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Re: cpp tilt
I bought the auto tilt and its a little shady, the indicator plate looks like a three year old made it, the hold down for the indicator plate doesnt line up with the screw holes, the bearing ant the bottom doesnt look right cant tell if the insides are grinding when I turn the wheel.
You wont have my issues with a 4 speed tilt but,,,,,you never know about the quality until it arives.
I have an GM auto tilt that I bought that was twice the price but its twice as nice......
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 05-26-2011, 07:31 PM   #5
alexr421
alexr421's Avatar
Re: cpp tilt
ok, thanks for the replies guys, that kind of worries me a little..this aint no show truck i have..but i dont want to put junk in it either..! have to think on it a little bit...
Old 05-28-2011, 11:29 PM   #6
oldspowered67C10
Re: cpp tilt
OK, got mine installed today so heres my opinion. I think its made in China since it has alot of quality control problems typical of China made stuff, but most of the problems are with the shift mechanism and wouldn't apply to a manual trans column.
Like 71meangreenc10 said, the indicator assembly is low quality. I was able to get the indicator to work well(the pointer points at the correct place in all gears) but I have a adjustable shift linkage and it took some fiddling to get it right.
When I first I first installed the shifter it wouldn't come out of park. It took some massaging with the dremel on the handle to get it to work.
The interlock system is a bit sloppy so when it pops into each range it doesn't feel as nice as a rebuilt OEM or high quality aftermarket Column.
The hazard switch on mine is very hard to operate, to the point where it feels like its going to break it and 2 of the 3 screws that attach the switch to the column were loose.
On the plus side, the fit was nice, the powder coat finish is nice and the tilt mechanism works well.
Overall, its cheaper and it shows it but it is a functional column and I think especially in a manual trans set-up its a viable option for a driver type truck and the price is right.
If you're putting it in a 67 or a 68 there's a few things to keep in mind though. It uses the 69-later flat style electrical connector for the signal switch but adapters are available. Also if I'm not mistaken, the splines for the steering wheel and possibly the steering shaft in 67-68 are different from 69-later and this column has the later style so the 67-68 factory stuff might not work so well with it. I put it in my 67 but since Im going to use a aftermarket wiring harness, steering shaft and steering wheel these were all non-issues for me.
Old 05-28-2011, 11:42 PM   #7
m6z
m6z's Avatar
Re: cpp tilt
I'm glad I ran across this thread. I'd be on the fence about ordering one of these. Think I'll just spend the coin and get a rebuilt one from the forum.
Doug
Looking for a 67-72 short bed driver.....
m6z is offline   Reply With Quote
Old 05-29-2011, 12:07 AM   #8
KevsClassics
TILT COLUMN GURU
KevsClassics's Avatar
Re: cpp tilt
I agree 100 percent.
Instagram
kevs_classics64
64 Impala SS Conv
72 Blazer 2wd
75 Jimmy 2wd
63 Belair wagon
02 Silverado ext cab. DD
RIP EL JAY
KevsClassics is offline   Reply With Quote
Old 05-29-2011, 12:15 AM   #9
m6z
m6z's Avatar
Re: cpp tilt
Yep, you're the guy to talk to. I'll be in touch whenever I get to that point in my build.
Doug
Old 05-29-2011, 06:16 AM   #10
Re: cpp tilt
Do these CPP columns look factory? Got pictures?
And,how much money are we talking?
Old 05-29-2011, 07:19 AM   #11
Number98
Prestige Worldwide
Number98's Avatar
Re: cpp tilt
Actually man if you want the stock look, Ididit offers a "retro Fit" line which look very close to stock for our trucks and though they are proud of them they are actually only a couple dollars above what the CPP one costs. I have been looking at column shift versions and came across them...
Number98 is offline   Reply With Quote
Old 05-29-2011, 10:25 AM   #12
alexr421
alexr421's Avatar
Re: cpp tilt
guys , i appericiate all the imput on these columns, im still on the fence but i will look into the ididt retro fit..i didnt know they had one like this..! and i have talked to one of the board members too, just waiting until after the holidays when they get back ..!
Old 05-29-2011, 11:33 AM   #13
MudBug
MudBug's Avatar
Re: cpp tilt
Who on the Board rebuilds columns?
MudBug is offline   Reply With Quote
Old 05-29-2011, 12:14 PM   #14
KevsClassics
TILT COLUMN GURU
Re: cpp tilt
Hello.
Instagram
kevs_classics64
64 Impala SS Conv
72 Blazer 2wd
75 Jimmy 2wd
63 Belair wagon
RIP EL JAY
Old 05-29-2011, 03:21 PM   #15
71meangreenc10
Re: cpp tilt
They look factory, but the quality is eeeehhhh...Less than 300 I think is what I paid.
Smitty
71 C30 Wrecker
Old 05-30-2011, 09:47 PM   #16
Number98
Prestige Worldwide
Number98's Avatar
Re: cpp tilt
Hello.
Really...
Old 05-30-2011, 11:58 PM   #17
71 super
71 super's Avatar
Re: cpp tilt
I have a CPP column that I bought a while back off the board. It looks to be a quality piece, but it uses the later flat type turn signal connection. It is the same length and in overall appearance looks just like the factory tilt I am pulling to use it for. The truck it is going in is being sold and I would rather save the truck tilt, so I guess therein lies the true answer.
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 05-31-2011, 02:02 AM   #18
alexr421
alexr421's Avatar
Re: cpp tilt
well i guess i will go ahead and get a rebuilt column off one of the forum members..its my understanding that the van tilt is shorter than a truck tilt..does this mean that it will give me more "gut" room..or is it on the other end..?
Old 05-31-2011, 06:46 AM   #19
Re: cpp tilt
Can't someone who has a CPP column take a picture? This all seems like worthless info to me until I can actually see for myself how much they look like OEM. I didn't think the Flaming Rivers looked all that different in floor shift. And,I know they are top quality.
Old 05-31-2011, 07:10 AM   #20
Number98
Prestige Worldwide
Number98's Avatar
Re: cpp tilt
Try this...
http://67-72chevytrucks.com/vboard/s...d.php?t=386300
Old 05-31-2011, 08:16 AM   #21
71meangreenc10
Re: cpp tilt
Ill see what I can do.....
Smitty
71 C30 Wrecker
Old 06-05-2011, 06:02 PM   #22
71meangreenc10
Re: cpp tilt
Ok,
Heres the pics,
Pic one shows the CPP indicator, not to quality if you ask me.
Pic two shows the finish, its quality.
Pic three shows the bearing, hard to get a pic with the booster in the way but its slanted at the bottom, not slush.
Pic four shows the GM tilt bearing, nice and straight.
Pic five shows the GM indicator.
Smitty
71 C30 Wrecker
Old 06-05-2011, 06:24 PM   #23
Scottshotrods
Re: cpp tilt
Need to buy Ididit coulmns they are made in the USA and have a lifetime warrantty and have all gm internal parts in them and there quality is 100% and if you are not happy with it they will send you one out to you for exchange.They have specifice made coulmns for your truck you have and it is a bolt in application.
The down side is they are alot more money than ones you are talking about but you have to pay for quality.
For the best DEALS on Ididit p/m me or e-mail me at email justin@scottshotrods.com email.I have KILLER DEALS and very fast shipping.
Justin
Scottshotrods is offline   Reply With Quote
Old 06-05-2011, 10:13 PM   #24
BossHogg69
motor exploder
BossHogg69's Avatar
Re: cpp tilt
Man, that indicator looks terrible... that would bug the p!ss outta me everytime I put it in 'Drive'!
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 06-05-2011, 10:38 PM   #25
KevsClassics
TILT COLUMN GURU
Re: cpp tilt
Pic
Instagram
kevs_classics64
64 Impala SS Conv
72 Blazer 2wd
75 Jimmy 2wd
63 Belair wagon
RIP EL JAY
