Old 05-26-2011, 01:17 AM   #1
rawraw67
rawraw67's Avatar
Let see some wheel tubs
I want to do rear wheel tubs on my 57 chevy.what are you guys using?
rawraw67 is offline   Reply With Quote
Old 05-26-2011, 02:53 AM   #2
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
Re: Let see some wheel tubs
depends what size ties using i got 31inch tires on mine but its a 1972 not 1950s
some guys take old tubs and weld two of them together
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 05-26-2011, 10:22 AM   #3
01spirit750
On my 57 I just needed about 1" more of clearance and I did not want to do the massive pro stree tubs. I found a late 40's Dodge truck in the wrecking yard and it had nice little 2" wide factory tubs. So I cut these and used them. They worked out nice.
Another option is to go to a trailer parts supply and buy a set of trailer fenders and use those as tubs.
http://www.etrailer.com/Trailer-Fend...F13X36-1R.html
01spirit750 is offline   Reply With Quote
Old 05-26-2011, 03:15 PM   #4
rollinrooster
rollinrooster's Avatar
I have a set of Dennis Carpenters universal wheel tubs for my '49. The tubs are around 2.5" wide and come in different diameters for different size wheels/tires. I will try to post some pics of them asap.
rollinrooster is offline   Reply With Quote
Old 05-26-2011, 08:32 PM   #5
52 Rat
52 Rat's Avatar
I'm going with the trailer fender set up. Norther Tool and Tractor Supply has the trailer fenders in stock. Plenty of sizes to choose from.
My build project http://67-72chevytrucks.com/vboard/s...=1#post4158671
52 Rat is offline   Reply With Quote
Old 05-26-2011, 09:58 PM   #6
entourageguy
Yellow truck club
entourageguy's Avatar
This is what I did on my 59.
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
Old 05-26-2011, 10:20 PM   #7
52 Rat
52 Rat's Avatar
Attachment 752584
Attachment 752585
What are the wheel wells from? Any details?
Old 05-27-2011, 12:37 AM   #8
55metalmonkey
x3 on the trailer fenders, there wide enough to cut in half and do both sides with one a grand total of $20
55metalmonkey is offline   Reply With Quote
Old 05-27-2011, 05:39 AM   #9
S10Fan
Old Heap Driver
Since mine has a bridge notch and raised floor, I went with this...............
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 05-27-2011, 07:43 AM   #10
entourageguy
Yellow truck club
Attachment 752584
Attachment 752585
they were out of a later gm straight side with the wood floor. I narrowed them about 4".
You could also use a set from a 58-58 straight side as well.
Brian ......
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
tilt, 4 wheel discs
4-link and bags
10 bolt limited
Old 06-16-2011, 11:11 PM   #11
52 choptop
52 choptop's Avatar
I'm running 31x18.50's. It's a different look, but you can't beat shiney!
52 choptop is offline   Reply With Quote
