Old 05-26-2011, 10:07 AM   #1
fun in dirt
fun in dirt's Avatar
Coating in wheel wells?
What was the textured coating used originally in the wheel wells?
I want to recoat mine with something similar & textured like that.
Want something that will clean up good to.
Thought about using 3M Body Shutz, but we have it under our car & if it gets dirty you can about forget getting it clean again. Any ideas???
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432
'85 K30 "Big Nassy"
[B]'85 C10 [B] "Corpse"
'01 2500 Suburban ...party wagon & tow truck
'06 Silverado SS...DD
'06 C1500 WT...DD
'07 Classic C1500 WT...DD
Built & sold cause can't keep 'em all:
'72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190
'55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938
'69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541
'86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619
fun in dirt is offline   Reply With Quote
Old 05-26-2011, 10:15 AM   #2
Mike Bradbury
Mike Bradbury's Avatar
Re: Coating in wheel wells?
What about spray in bed liner? seems to clean ok.
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale
Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961
Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583
Mike Bradbury is offline   Reply With Quote
Old 05-26-2011, 10:39 AM   #3
72TealnWhite
72TealnWhite's Avatar
what about a textured coating on the frame and wheel wells ? was this used in the 70's to fight off against rust? was it put on by the owner? it almost looks like fiberglass matt.. i'm sure it is not.. anyone know what this stuff is? and will it be a problem in the future? looks to be like something applied to fight off rust like sprayed on as if you would spray on a fire retardent on steel beams... thanks
72TealnWhite is offline   Reply With Quote
Old 05-26-2011, 04:55 PM   #4
BBrendal
Recalculating.....
BBrendal's Avatar
Cant you just use undercoating? Thats what I was going to do.
Brian - (BBrendal)
1969 Chevy Camaro Z28
1972 Chevy Blazer CST
2004 GMC Yukon (The truck that pulls the car trailer)
1972 Chevy Blazer CST #2 (Finished and sold!)
Blazer build link...
http://s1213.photobucket.com/albums/...rendal/Blazer/
BBrendal is offline   Reply With Quote
Old 05-27-2011, 09:07 AM   #5
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Im with Bradbury... I think Im going to go with Linex on mine.
Tom Vogel is offline   Reply With Quote
Old 05-29-2011, 12:17 AM   #6
cleszkie
cleszkie's Avatar
3M makes a spray-in rubberized undercoating. Comes in a rattle can. Probably not as durable as bedliner though.
cleszkie is offline   Reply With Quote
Old 05-29-2011, 08:31 AM   #7
bigpig72CST
I have always been told not to use undercoating b/c it will hold moisture, but I don't know if this is true?? I'm also leaning towards a spray in type bed liner, that seems a lot more durable.
bigpig72CST is offline   Reply With Quote
Old 05-29-2011, 11:14 AM   #8
72lb4x4
A textured coating on the frame is probably overspray from dealer or aftermarket rustproofing, especially in Michigan. Google Ziebart if you want... I think he was the original rustproofer.
72lb4x4 is offline   Reply With Quote
Old 05-29-2011, 01:52 PM   #9
notsolo
notsolo's Avatar
I am going with UPOL raptor polyurethane bedliner.Comes in 2 part kit mix and spray on. The original was cracked and peeled off in big chunks. I'm done with the prep clean/scrape/kerosene. I hope this holds up as good as the original, 40 years later.
notsolo is offline   Reply With Quote
