Old 05-26-2011, 05:15 PM   #1
jimmydean
jimmydean's Avatar
Non-OE dash clock retrofit.
So I am knee deep in dash clock options and I was wondering what (or if) anyone else has done for a gauge cluster clock in a 64-66 dash.
Some obvious choices:
Square body dash clock retrofit
Any classic car/truck clock
New aftermarket (autometer or other)
Or something totally random?
My gauges are now white, so whatever I do will be done with a white face. So the color doesn't matter so much.
Looking at totally random, the Chrysler 300M clock looks very nice (early models don't have the logo)
The Escalade clock is sweet, too and would go:
Of course there are a million analog clocks, but what has anyone used outside of stock ones?
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 05-27-2011, 09:46 AM   #2
66Gilbert
1966 Crew Cab & 4X4 Fanatic
66Gilbert's Avatar
Re: Non-OE dash clock retrofit.
I bought this clock off ebay over 3 years ago from a vendor named The Clock Doc. It was made specific for 60-66 clusters to look OEM. Had to modify the face plate very little to install.
66Gilbert is offline   Reply With Quote
Old 05-27-2011, 09:56 AM   #3
LeftCoast32
Custom Builder
LeftCoast32's Avatar
That is a very nice Tach and Clock Dash Cluster!
LeftCoast32 is offline   Reply With Quote
Old 05-27-2011, 10:06 AM   #4
lakeroadster
The ultra rare rare mid 60's "tick-tock-tach" dash... sweet!
lakeroadster is offline   Reply With Quote
Old 05-27-2011, 10:08 AM   #5
LeftCoast32
Custom Builder
I have not heard that in a very long time! Thanks for the bounce back in time!
Old 05-27-2011, 10:33 AM   #6
lakeroadster
I have a '69 Camaro SS. It's a numbers matching car, which I respect, but I am not a "numbers matching" guy.... the purests go nutso for the factory stuff like tick-tock-tachs.
I get a kick out of watching the insane prices these purests will pay for the stuff that alot of us back in the day thought was soooo hokey.
Old 05-27-2011, 10:40 AM   #7
LeftCoast32
Custom Builder
I had a 1967 RS Camaro Convertible (275HP 327) with every option except the SS. It had the Deluxe Interior with Tach and Console Gauges. It was hard to find parts to restore that one almost 20 years ago. The first gen Camaro stuff goes for top dollar!
Old 05-27-2011, 11:49 AM   #8
jimmydean
jimmydean's Avatar
I think I'm sold on the BVLGARI, I might try and pick one up this weekend. I don't want to cut the hole out if I can avoid it.
Here is my hokey mock up
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 05-27-2011, 03:25 PM   #9
198plus
198plus's Avatar
Here's mine with clock.
198plus is offline   Reply With Quote
Old 05-27-2011, 04:40 PM   #10
jimmydean
jimmydean's Avatar
Did you just use a hole saw to cut out the hole for the clock? My concern is getting the hole to look right, thats one reason I was looking to squeeze the clock into the small location.
I think I might just spend a few hours in the bone yard and see what I can find.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 05-28-2011, 09:50 AM   #11
66Gilbert
66Gilbert's Avatar
I cut the bottom half of the circle with a plasma cutter and then used a die grinder with a fine burr and a sanding flap wheel to clean it up.
Old 05-28-2011, 12:27 PM   #12
dtkarst
66Gilbert; Where do you find a clock like that one on ebay?
dtkarst is offline   Reply With Quote
Old 05-28-2011, 12:45 PM   #13
66Gilbert
66Gilbert's Avatar
I found this on ebay 3 years ago. I am not sure if the Clock Doc is still around on ebay. If I remember correct they only made a small number of these clocks. I would type in dash clocks in the seach.
Old 05-28-2011, 02:10 PM   #14
kieth
kieth's Avatar
You might check with williamsons in Arkansas, they redo, replace, about any type of gauge or clock......Kieth They just completely updated my old 5000 rpm sun tack made it a stand alone electronic unit for $219.00
kieth is offline   Reply With Quote
Old 05-28-2011, 10:15 PM   #15
jimmydean
jimmydean's Avatar
U-Pull-It is having a half off weekend and clocks are only $2.50, so I might come home with a hand full and see what I can make work. So far the 300M clock is the nicest, but I have a list of ones to look out for. Pics to follow.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 05-29-2011, 12:28 AM   #16
DPowers
DPowers's Avatar
Try a mid-80's GM- Monte or possible Camaro.
DPowers is offline   Reply With Quote
Old 05-29-2011, 09:52 AM   #17
jimmydean
jimmydean's Avatar
The Ford 500 clock might work, but it's more silver than white.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 05-29-2011, 10:32 AM   #18
66Gilbert
66Gilbert's Avatar
Here is a white faced gauge cluster with clock that was on ebay.
Old 05-29-2011, 10:35 AM   #19
Rich 5150 69
Rich 5150 69's Avatar
The ad terminated Gilbert....LOL
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 05-29-2011, 10:41 AM   #20
jbgroby
jbgroby's Avatar
I was able to find an OEM set up on both the Tach and the Clock. I don't know which would the "correct" side to mount the clock/tack on, I don't suppose therer really is one?
jbgroby is offline   Reply With Quote
Old 05-29-2011, 10:07 PM   #21
jimmydean
jimmydean's Avatar
DONE!
2001 Chrysler 300M, $2.88 and it took almost noting to make it fit. I love it when a plan comes together.
<edit> Still not sure if I will keep the chrome ring, or got white.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 02-16-2013, 12:50 AM   #22
Slow Build
Slow Build's Avatar
Just bought this clock on ebay. I hope it will fit. It's advertised to be out of a 65-67 Chevy Impala (cluster or console). It looks a little busy but the face is 3" across which looks about right. I should get it in a few weeks. I'm crossing my fingers.
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 02-16-2013, 01:01 AM   #23
Daze57
Daze57's Avatar
good stuff guys !!!!-- all those clocks and clusters look great
Daze57 is offline   Reply With Quote
