Power Break Booster/MCs
So the local pick-a-part is having a memorial day weekend sale, and I just want to do some research before I head over there this weekend.
First off which other GM trucks have power break booster/MCs that can be directly bolted onto our trucks. I plan to run the drums up front for awhile until I save up the money to convert the truck to discs. |
Re: Power Break Booster/MCs
If you are converting from non-power to power then you will need the bracket and linkages from a 67-72 truck. I believe all 3/4 tons offered power brakes, but only 71-72 1/2 tons had them. I'm not sure about the m/c and booster on other year models but the bracket is the part you can't get aftermarket unless you go with an entire kit. I hope you find what you need.
Rich 1970 C/10 Step, 383/700R4 http://67-72chevytrucks.com/vboard/s...d.php?t=466601 Last edited by 70truckguy; 05-27-2011 at 03:50 PM. |
