power drum breaks
how hard and what does it take to make a non-power drum truck a power brakes equipped front and rear drum truck
![]() Join Date: Sep 2007
Re: power drum breaks
all I did was add a pb booster and pedal rod from a 72. you learn real quick to change you habits in how hard to push the brake pedal!
1967custom |
its all about the +6 inches
add the booster, the brackets that hold the booster to the firewall, replace the pushrod, that's it. You don't even have to replace the brake lines, just gently pull the master cylinder away from the firewall. I recently swapped mine from power (with a junk booster) to manual.
the boat guy
be careful I exploded a front drum on my 67 without power going down the highway.
I have power disc now.....
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
Active Member
Never try to teach a pig to sing; it wastes your time and annoys the pig! ![]() ![]() My lugnuts require more torque than your honda makes! 68 GMC, 4X4 conversion w/73 k20 running gear and springs, 350 4spd, 4.10's, D44 powerlok front, 14BFF govlock rear, 33" tires, lifted 4". |
Thanks for the info guys. Question, where does the vacuum line hook up to from the power booster on an inline 6?
#7 | |
Love That '69
![]() ![]() But all I did was buy a new power brake booster & added it to my manual drum brake setup. It was a VERY good upgrade!!!
I AM CANADIAN!!!!! ![]() 1969 Chevy C/10 Truck - SBC V8, TH-350, 3.73 Posi, 1000W Rockford Fosgate Stereo System, B&M Megashifter, GT Grant Steering Wheel, Dual Magnaflow Exhaust System, Dynomax Headers, Lowered 1" Front & 3" Rear, Front/Rear Sway Bars, Racing Seats, 6000K HID Headlights 2008 Chevy Colorado LT - 3.7L I5, 4 Speed Automatic, Crew Cab, 4X4, Z71 Off-Road Package, "Ground Effects" Package, K&N Cold Air Intake, Supermod PTB, Magnaflow Exhaust w/ Resonator, 500W Kenwood / Rockford Fosgate Stereo System, Custom LED Lighting, 6000K HID Low's / High's, Blackcat Customs Gauges / Needles, Carbon Fiber Interior Accents, KrFabs 2" Lift Shackles / Torsion Bar Crank with Rancho RS5000 Shocks, Superskids Skid Plates |
Love That '69
I believe on inline 6's (I used to have one) there is a pipe plug on the side of the intake manifold. Pull this plug out & put in a fitting for a 3/8 vacuum line hose. Hook this to the power brake unit.
Active Member
![]() Join Date: Jul 2007
Re: where to hookup.
You can remove the plug under the carb on the intake manifold and install a power booster adapter you can get at Auto Zone. I just did a brake job on my 68 and reinstalled my old brake booster that I removed a couple of years ago. If you go to the salvage yards for one, also get the brake push rod inside the cab. It's easier to remove the push rod after you remove the engine bay bracket asm. This way you can push the brake pedal forward to access the bolt. [IMG] ![]() [IMG] ![]() Last edited by 68gmsee; 05-27-2011 at 07:23 PM. Reason: ...meant intake manifold. |
Shattered drums is from lack of inspecting the drums... just like the shattered disk rotor I replaced last month at work on an international box truck.
