swap?
i have a 82 chevy n wanted to make it into a tbi...n i have a 91 camaro n was plannin on taking parts i needed for the conversion of my truck...is it possible???wat else would i need??or will the parts from my car even work on the truck?THANKS in advance
Re: swap?
The fuel pump wont work... at least I don't imagine it would. Will need a fuel pump from a fuel injected truck/van of similar vintage. The TBI should work fine as long as it is from the same/similar sized engine. Probably going to need the wiring/some sensors/computer and such, but you should be able to make it work.
Hopefully some of the more fuel injection knowledgeable guys will step in and give a more specific answer...
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
