05-27-2011, 11:32 AM | #1 |
disk brakes on all 4 corners
i am attempting to put 4 wheel discs on a 1967 1/2 ton p/u.
my basic concern is what combination/proportioning valve are you guys using.. would like to be able to retain most of the stock brake lines... any input would be great..
05-27-2011, 01:10 PM | #2 |
67-72 parts collector,…
Re: disk brakes on all 4 corners
http://www.performanceonline.com/GM-...-VALVES-PV672/
Part number PV2 is a disc/drum. You need part number PV4 for 4-wheel disc brakes. I would just purchase the entire M/C and prop valve combo. These aluminum M/C are great and will look good for a long time. You can paint them and not worry about them rusting later. I would just leave it bare aluminum. http://www.performanceonline.com/HIG...PVS-AMCPVS232/
05-27-2011, 01:45 PM | #3 |
thanks Keith.. i will take a look..
have a good holiday
