Old 05-27-2011, 08:44 PM   #1
tallcrown
Slow electric windows.
Asking for what works and what you have done about slow electric windows.
My Electric windows on my Suburban are very slow. They all work sometimes with a little help. I keep thinking that I can just open up the door panels and lube them. But have not yet.
Does anyone have experience with this problem. What has worked for you on your Suburban?
Any Help would be appreciated
tallcrown is offline   Reply With Quote
Old 05-27-2011, 09:30 PM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: Slow electric windows.
the same thing happens on pickups... you do need to lube them and that should help exponentially
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 05-27-2011, 09:31 PM   #3
mooseknuckles
mooseknuckles's Avatar
I seen somewhere someone had taken the motor assembly out and cleaned up the 20 some years of oil and dirt that was stuck to them, lubed them and stuck em back in and they worked like new...
mooseknuckles is offline   Reply With Quote
Old 05-27-2011, 11:44 PM   #4
soonerfans!crew
I had the same problem on my 81 ccsb and my friend suggested installing bosch style relays to the motors on all 4 of them. Now they work like they are brand new!!! The relays are cheap and a simple install.
soonerfans!crew is offline   Reply With Quote
Old 05-28-2011, 03:42 AM   #5
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
Got a schematic of the wiring of the relays and where you mounted them?
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 05-28-2011, 05:34 AM   #6
tallcrown
cleaning and lube. can you be more specific where they all hang up?
I would first think the rollers need a spray on them. Where else?
Cleaning? what/where/how.
This may seem like a stupid question. But I like to get to the specifics where the problem usually is and what is happening to cause it.
If I put a relay on the motors what does that do? If the motor works harder does that cause more stress on the rollers etc?
Anyone have any specifics guys?
Any and all help is appreciated
Old 05-28-2011, 07:43 AM   #7
mbgmike
I just had to do the fronts on my 91. cleaned everything up replaced the upper window door felt,beltline moulding and division bar channel and they work like normal. A 91 is not that old to me but the rubber is 20 years old
mbgmike is offline   Reply With Quote
Old 05-28-2011, 08:05 AM   #8
sumran
sumran's Avatar
I use Liquid Wrench silicone spray lubricant in the tracks and guides once a year. Makes a huge difference. The other suggestions may still be needed, but reducing friction reduces stress on all the components.
Randy Summers
Never brake in the learning curve!
1984 GMC Sierra project truck http://67-72chevytrucks.com/vboard/s...d.php?t=446737
sumran is offline   Reply With Quote
Old 05-28-2011, 10:45 AM   #9
rayfinseats
I hope you NEVER plan on painting your truck because silicone is a B***H around paintjobs. I NEVER use silicone spray around cars or armorall (armorall is very destructive to vinyl)
I'm working on the same problem right now with my windows. I noticed my seals around the window are binding, rollers are worn out, and I have a new motor coming. Will keep you posted.
rayfinseats is offline   Reply With Quote
Old 05-28-2011, 11:12 AM   #10
motornut
78K & 79C Jimmys
motornut's Avatar
the rollers, the tracks, anywhere there is goo ,clean it and use some new grease
i've found the older stuff baked hard and dried
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 05-28-2011, 03:34 PM   #11
soonerfans!crew
Dont have a schematic but I can draw one up for you. Going out of town for a couple days but I will get one and a pic of mine install.
