Shorten steering column on 56 Apache
I am looking for step by step instructions on how to shorten my 56 Apache steering column. Is there a thread on this or does anyone have some pictures?
Re: Shorten steering column on 56 Apache
Are you talkin about a stock column? If so I've never heard of that. Most put in a later model one. but I have not seen every thing...
'57 Chevy Pickup '56 GMC LCF Cummins '38 Chrysler Royal '57 2wd change http://67-72chevytrucks.com/vboard/s...light=speedway |
Yes the stock one
There have been a couple of guys take some off the bottom to use the stock enclosed column with a newer box. There are vendors that sell a bottom bearing with the correct steering shaft inside dia. and tube side o.d. I did a quick search and could not find it maybe someone else will remember who did it and chime in.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
Hollister Road Co.
If your looking to keep a stock column and box then get a 57-59 unit its about 2" shorter. You will need the shifter from the 57-59
