Active Member
![]() Join Date: Dec 2004
F/R Drop spring height of springs?
I just picked up what is supposed to be a front and rear lowering kit consisting of front and rear springs and four shocks today at a swap meet. In comparing the front and rear springs to stock ones they appear to be the same height as the stockers, although it appears the rears have at least 1 less coil in them.
Is it possible the drop is achieved by spring rate only, or should I see a difference in height between the drop springs and the stock ones? The fronts were compared with a known set of stock strings that were out in the open, and the rears I held up to my stock ones which are still installed, but with the bed removed and the truck up on a lift with the rear suspension unloaded. They both appear exactly the same height. Is this normal, or did I get taken? (By the way, I only paid $45 for everything, and my front is already lowered with cut springs so I won't mind having a stock set around, if indeed that is what they are. It would be nice to have rear drop springs though, since the rear is not yet lowered.)
1957 GMC Ambulance 1962 Belair Wagon 1963 C80 Truck Cab *FOR SALE* 1969 Chevy C10 Short Bed 1972 Chevy C10 Long Bed *SOLD* 1996 C3500 Dually *SOLD* Last edited by 7T2; 05-27-2011 at 10:33 PM. |
Active Member
Re: F/R Drop spring height of springs?
Anyone?
1957 GMC Ambulance 1962 Belair Wagon 1963 C80 Truck Cab *FOR SALE* 1969 Chevy C10 Short Bed 1972 Chevy C10 Long Bed *SOLD* 1996 C3500 Dually *SOLD* |
Active Member
I seem to remember a thread here that compared the different heights of drop springs with stock springs, as well as the height of trucks with different springs installed, but I can't seem to come up with the right search terms to bring it up. Anybody else remember what I'm talking about?
67-72 parts collector,…
![]() Join Date: Nov 2002
It's hard to compare spring "measured un-installed" heights.
Spring rates and wire diameter will result in different drops. I would just measure the before height,... and then install your new parts. That's only way you will truely know.
#5 | |
Active Member
I think the fronts are stockers though...they look EXACTLY like stock springs, same coils, diameters, thicknesses, and they have rust on them at the top, although they aren't as crusty as most 40 year old springs. Who knows. I am at a point where it won't be too bad to swap the rears, but I probably won't know for sure until I get the bed back on how much the drop will be, if any.
Active Member
Still looking for a definitive answer to this, if anyone has had both stock and drop springs and compared them. Were they the same height, or noticeably different?
again, you can't compare heights of uninstalled springs to find drop amount
