![]() Join Date: Sep 2000
Heater
Has anyone got pic's of the rear heater installed in the sub or panel?
69 stepside, 1/2ton, 4X4, 350/350/205 |
Re: Heater
what year? I've never seen them, even here in the northeast, interested though.
Re: Heater
67-72
Re: Heater
Mine had a heater but I took it out while working on it and have not put it back in yet. My rig came from Michigan once upon a time. I probably won't need it here in Missouri, but it's kind of neat.
What are you needing to see or know?
1970 Chevy 3-door Surb (in progress) |
its all about the +6 inches
Re: Heater
Gm didn't install one
Re:heater
Thats funny, because my 72, 10-30 series truck service manual shows it as an auxiliary heater on page 1A-5.
Wanting to see how and where exactly it was mounted in back on the floor. Also would like to know what make and/or model the heater is.
69 stepside, 1/2ton, 4X4, 350/350/205 Last edited by ole red; 06-03-2011 at 11:16 PM. Reason: more information added |
Re: Heater
Mine was mounted just inside the third door to the left as you are looking in. I had a narrow 2nd row bench that allowed people to slip past the seat to get into the rear. It was in between the door and the passenger side rear fenderwell on the vertical surface of the truck, not the floor. Behind the side panel is some bracing, that bracing is used to also mount the heater box. The rubber hose run down and under the truck to the main heater core with an old water valve to shut it off if needed.
Re: Heater
I guess I shoulda asked quesions. I assumed you were talking about the overhead A/C... with heat.
However, I had never seen/heard of what is being described here either. |
What?
Re: Heater
I have never seen, nor have I ever heard of a rear heater for a burb.
But, I suppose one could be rigged up. I keep flashing to the heater a buddy of mine had in his 59 GMC, since it was a after market style and looked like a little box. I could see mounting that thing anywhere if you had the space, but I can't stop thinking about how much plumbing it would take to run off if engine coolant. Plus, if the truck was in a cold environment - how hard it would to get the engine to operating temp, and God forbid there was a shortage of anti freeze in the water. Just rambling out loud...
Chris 1968 K20 Suburban 1972 K10 LWB PU |
Re: Heater
pics of heater
member
Re: Heater
I had a burb with the rear heater. The truck was purchased in Montana.
1967 C/K10 Chevy Panel 1968 C/K20 Chevy Pickup 1968 C/K10 Chevy Suburban 1941 Chevy Sedan Delivery 1960 Chevy Sedan Delivery 1972 Camaro SS 396 #s matching 1971 Harley FX Superglide |
Re: Heater
outstanding pic there red, thanks!
#13 |
Re: Heater
I thought it would help to clear up some confusion. Still would like to see how it was mounted and make of the heating unit and if it is still avilable.
