Old 05-28-2011, 10:23 AM   #1
darush01
Help!!!!! Please
Ive been working on getting my truck driveable for about two weeks now i notice my headlights dont work anymore neither do my tailights and the turn signal only works on the right i have front parking lights but thts about it what could cause this, i tried to see if brights would work and they dont
darush01 is offline   Reply With Quote
Old 05-28-2011, 11:47 AM   #2
cdowns
cdowns's Avatar
Re: Help!!!!! Please
for your headlights i'd first check the dimmer switch to see if you have voltage going to the dimmer if not then i'd b lookin at the headlight switch
as far as turn brake and parking lights i'd first make sure you have a good ground on all of them
Old 05-28-2011, 12:25 PM   #3
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Don't forget the fuses.
Zoomin is offline   Reply With Quote
Old 05-28-2011, 08:00 PM   #4
68 Stepside
huh?
68 Stepside's Avatar
CDowns and Zoomin have good tips. I would also say check the dimmer switch on the floor for the headlight issue. Check all of your grounds (body to frame, engine to frame, light buckets to body/frame). I had bad grounds on my truck that would actually make my headlights flicker if I hit a good bump or moved the shifter. I put a nice heavy gauge wire between the firewall and frame as well as the engine to frame. That took care of my issue there. I also had an issue with intermittent/dim taillights. A good heavy ground wire from the bed to the frame fixed that problem as well.
I've also seen a bad turn signal switch do goofy things, try wiggling it around and see if any marker/taillights come on.
Good luck, keep us posted.
Someday when I'm lonely,
Wishing you weren't so far away,
Then I will remember
Things we said today.
RIP El Jay
68 Stepside is offline   Reply With Quote
Old 05-29-2011, 07:47 PM   #5
darush01
I found out tht if i turn my left signal on my tailights work if the switch is pulled
