Old 05-28-2011, 11:16 AM   #1
into69z
"brand new second-hand"
into69z's Avatar
anyone had this happen before? (yet)
Noticed today that when I use the turn signals, the drivers side blinks as normal but when I use the passenger side it goes really slow-it blinks but really slow. I changed the flasher unit in the fuse panel and checked both bulbs and they work, again just slow. any suggestions on what to do next?
Steve
69 3/4t custom camper
tilt,am/fm,speed warning,air gauge,buddy buckets,aux battery, big block,p/s,p/b,a/c
67 Camaro
96 Impala ss-sold
04 hybrid Honda-saving gas for the blue truck!:
b69:
into69z is offline   Reply With Quote
Old 05-28-2011, 11:21 AM   #2
Fldawg
Fldawg's Avatar
Re: anyone had this happen before? (yet)
check for a bad ground
Fldawg is offline   Reply With Quote
Old 05-28-2011, 11:49 AM   #3
BlackTopMotors
agree with the ground check, follow the wires inside your radiator support/inner fenders to see if one came undone, also make sure all your turn signal bulbs are working. Make sure turn signal wires are connected tightly (the factory rubber connectors)...hope you solve it.
BlackTopMotors is offline   Reply With Quote
Old 05-28-2011, 10:32 PM   #4
Zoomin
Man of Mini-Talents
Zoomin's Avatar
The side marker bases also need to be grounded, so be sure to check those in addition to the turn signal bases.
Zoomin is offline   Reply With Quote
