I have 1976 GMC sierra classic 4x4 and I have heard that switching from 1/2 ton axles to 3/4 ton axles will give me the gear ratio to run 35" tires for cheaper then regearing the stock axles I have on my truck. Would axles off a 3/4 ton truck of the same year bolt on to my truck's mounting points or would I have to do som e custom work? I have a 6" lift all leaf springs. I don't know if makes a difference it is a short bed.
Posted via Mobile Device |
Re: axle swap
1/2 and 3/4ton are the same all the way around and 1 ton are the same up front. To run 35's you are going to want to look for 4.10 gear ratio.
![]() 1949 Five Window, 1973 Step Side, 2000 Z71 |
Re: axle swap
Just for reference I have 35s on my truck, stock 1/2 ton axle...sorry don't know the ratio right now I just got it. It performs alright, granted I don't drive on the road with it either. It spins through the mud real well though.
Build it for go before show, and go big or go home! 2006 Ford Focus SE ZX3-89K 2.0L/MT 5spd -- Sold 1984 GMC Sierra Classic K1500 350/700r4/np208c(low gear 261) all stock otherwise(workhorse/pull truck) -- Sold 1974 Chevrolet Cheyenne K1500 366TD/SM465/np205 6" lift with 35s 1/2ton axles (project/mudder) -- Sold |
Re: axle swap
Your 76 has a dana 44 front and a 12 bolt rear axle. Standard ratio was most likely a 3.08 with a 3.42, 3.73, and possibly a 4.10 being optional. Upgrading to 3/4 ton axles Will get you either a dana 44/corporate 10 bolt front axle and a 14 bolt rear axle. Standard ratio should be 3.73 with 4.10 and 4.56 being optional. 1 tons use a dana 60 front axle with a 14 bolt rear.
With 35's, look for 4.10s or 4.56s. 3/4 tons will bolt right in. There are some minor changes to make to run a dana 60. The spring perches on the 1 ton 14 bolt are set up a little narrower than the perches on the 1/2 and 3/4 axles. Dont forget that the 3/4 and 1 tons are 8 bolt wheels.
70 stepside 76 blazer 86 Silverado 20 Max Trailering 6.2 Crew 71 Nova SS My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=363634 Last edited by russgt; 05-29-2011 at 03:54 PM. |
