Old 05-28-2011, 02:36 PM   #1
66 lwb cs
66 lwb cs's Avatar
GM Corporate 14 Bolt ?????
Does anyone know if the GM Coporate 14 bolt rear end will bolt up to a 66 3/4 ton long bed with coils and if it is about the same length the one I found came out of a 69 big block truck
66 C20 LWB CS 327/TH400 A/C
66 lwb cs is offline   Reply With Quote
Old 05-28-2011, 04:31 PM   #2
firenuttz
2lo4me/ntlonuf/ntfstnf
firenuttz's Avatar
Re: GM Corporate 14 Bolt ?????
if it didnt come out of a truck with coils it wont bolt up but you should be able to get the mounting perches through lmc and it should be the right length if it came out of a 69 then you might have to get a different panhard bar or make a mount for your current one
62 GMC swb fleetside~ project: still undecided
84 Chevy 4wd crew cab 8 inch lift and 37" goodyear h1 pulloffs, still rockin the old mans former plate 2LO4ME
65 chevy 1 ton panel~ bagged/bodied duramax plans slowly in progress...
02 Silverado cclb duramax~ sas'd "bro" truck with more rust than imagineable...
firenuttz is offline   Reply With Quote
Old 05-29-2011, 01:03 AM   #3
Captainfab
60-66 Nut
The 14 bolts didn't come out until '73. If you're looking at an original '69 big block C20 rear end it very likely is a Dana 60. It might have 3.54 gears if it was an auto trans truck. The panhard bar will be shorter than your '66 with the HO52 rear end.
If the rear end you are looking at is indeed a 14 bolt, I have a pair of the trailing arm mounts for them. The typical trailing arm brackets that you buy won't fit as the 14 bolt has a larger axle tube diameter than a 12 bolt.
Old 05-29-2011, 01:11 AM   #4
66 lwb cs
66 lwb cs's Avatar
This is one that I found
http://denver.craigslist.org/pts/2327425289.html
This is the other
http://denver.craigslist.org/pts/2401105831.html
Old 05-29-2011, 01:24 AM   #5
firenuttz
firenuttz's Avatar
yap that there be a corperate 14 bolt
id go with the 14 bolt cuz ive seen those things go through hell and hold up
only one downside though, you dont know the gears, it could have 4.56s and that could be a problem,find out what gears it has then think if they will apply to your application
Old 05-29-2011, 10:03 AM   #6
66 lwb cs
66 lwb cs's Avatar
Thanks for the info but my question is will it bolt up with no mod other than the u bolts and are there gears available for it in say the 3:55 range or is it relegated to the steeper gears like the HO52? Also is it the same width for wheel fitment? Thanks in advance.
Old 05-29-2011, 10:21 AM   #7
LeftCoast32
Custom Builder
LeftCoast32's Avatar
The 14 Bolt Full Floaters and Semi Floaters have alot of different gear choices.
The 14 Bolt I built for my '66 had 3.73 gears and an open carrier when I purchased it.
The open carriers in the 14B FF can be changed over real easy to a locker with a Detroit Locker that bolts right into the open carrier.
If I build a 2 wheel drive I will cut down a newer 14 Bolt Semi Floater. They have disc brakes already and they are even stronger then a 12 Bolt. I have a company that builds us Forged Axles for them and we can have any bolt pattern put in the axles.
LeftCoast32 is offline   Reply With Quote
Old 05-30-2011, 12:27 AM   #8
Captainfab
60-66 Nut
It is impossible to say if that FF 14 bolt will just bolt into your truck without knowing whether it is setup for leaf springs or coils. Since the 14 bolt didn't come in that '69 originally, it's hard to say. The 3.73 and 4.11 gears are failry common in the FF 14 bolts. Although I believe 3.42 and 3.08 gears were available, but not very common or easy to find. I have measured a '74 FF 14 bolt and compared it to a '66 HO52, and the 14 bolt is a little wider.
Old 05-30-2011, 12:54 AM   #9
66 lwb cs
66 lwb cs's Avatar
Thanks again Captain for the info thats what i was afraid of I wanted to try and keep the same dimensions as my stock axle as well as keeping it a bolt in affair. I guess that will be harder than I had hoped. As for the axle pictured the first one has coils in it for the 1969 truck the picture is upside down took me a while to figure it out will have to call on the one with the 3 axles pictured to find out exactly what it came out of.
