Steering column length
Anybody happen to know the length of the steering column on my '63 step side column shift? 30", 32" or 33"?...and, when ordering a replacement column, does it matter if my transmission has overdrive (granny gear) or not?
ABOZ |
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
Re: Steering column length
where are you ordering from? yes it will matter for the aftermarket ones since they sell the indicator too.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
My column I bought from CPP came with 3 and 4 speed indicators for the auto trans also the shifter bracket is different for 3 and 4 they sent both of them too.
Just in case you interested CPP is having a 3 day Memorial weekend sale, use code MD2011 for 10% off
Indian, Can you tell me which column you ordered from CPP. Thanks.
c10 Chop Artist
If you use a universal fit column i believe you need a 33".
![]() Join Date: Dec 2010
I bought the ECSC-S 33 inch both 3 and 4 speed came with it, still in the box, they(CPP) also hooked me up with everything to the pwr steering gear, column looks great and was by far the best price vs all the others I looked at, this was about 3 or 4 months ago, looks like they made some changes to the catalog but give em a call 800-522-5004
Im a big guy do yall think a 30" will work and give me some extra "room"?
![]() Join Date: Oct 2010
I also went with the CPP universal 33". You have some play in which you can move it up or down.
TAZ BUILDS 1966 GMC Suburban 1963 GMC Suburban Patina frame-on FOR Sale 1966 C10 Short Bed (2010-11) Monthly Updates 2015 C10 Pics with my '72 Montego GT 429/521 build 1963 Pro Street C10 back halved. Frame off I did back in 1990 Pics / Video |
I bought the Economy 33in. Street Rod with auto shifter. I haven't put it in yet as I'm putting in a 700r4 first.
I bought a 33" colum ,also from cpp.
#12 | |
For instance, I put a '78 suburban tilt column in mine, which tends to run a bit long. Cutting the beauty ring gets it close to the dash and that is where you make some room. Last edited by wildearp; 05-29-2011 at 08:30 PM. |
#13 |
Found the photos:
![]() ![]() This is a 73-87 Suburban column. I cut the round steering shaft and ground it into a DD. It is a driver at this point, so things are not so clean. ![]() |
