C notch
Any posts on C-Notching??
One day...
Re: C notch
Do a search in and type in any questions and a bunch of threads will come up.
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: C notch
What year truck?
Re: C notch
1965. I want to lower is 2 more inches, it has 4 inch lowering coils and 2 inch up front I want it to be 4/6. Would I use drop shackles...?
Posted via Mobile Device |
Re: C notch
Drop shackle is for rear leaf springs.
Is your truck coil or leaf?
Re: C notch
coil. What could I use to drop the rear??
Re: C notch
6" rear spring from Early Classic Enterprises.
Re: C notch
thats the only way to get lower? I just bought the 2/4 from them....
Re: C notch
You could add a 1.5 inch block.
I would sell the 4" springs and buy the 6" springs. No notch required. Anything lower than 6" and you will need a c-notch. Posted via Mobile Device
Re: C notch
How do blocks work?
Re: C notch
Try using google when you have questions you need answered. Alot of times, you can get direct hits for this site that will give you the basic info needed. If it's a more involved issue, this community is here to help but you need to put some effort into it as well.
I went to google & entered "how do lowering blocks work". This was the 2nd hit.... http://www.google.com/url?sa=t&sourc...NRPjO6R9kupcZg
Re: C notch
That's great. Thanks. I usually do ask google. But I figured I trusted you guys more.
#13 |
Re: C notch
Frame Notching.
Check out the link in my signature line.... Last edited by lakeroadster; 05-29-2011 at 01:50 PM. |
#14 |
Re: C notch
Where is it?
#15 |
Re: C notch
Click this link: Notching Your Frame, Check This Out First
