Old 05-28-2011, 08:39 PM   #1
chainsaw
chainsaw's Avatar
Chevy 400 pros & cons
Any one running a 400 chevy, seems I heard they overheat. Pros or cons ? Thanks.
chainsaw is offline   Reply With Quote
Old 05-28-2011, 08:39 PM   #2
99-LS1-SS
99-LS1-SS's Avatar
Re: Chevy 400 pros & cons
Big block or small block?
99-LS1-SS is offline   Reply With Quote
Old 05-28-2011, 08:41 PM   #3
LeftCoast32
Custom Builder
LeftCoast32's Avatar
I have run alot of small block 400's over the years. They have great torque and so long as you have a good cooling system they are no different then a 350.
LeftCoast32 is offline   Reply With Quote
Old 05-28-2011, 08:53 PM   #4
badblu97
Double 6's
badblu97's Avatar
Actually getting ready to swap in a 400 in my 66....hope I can get the cooling under control!
Street Glidin!
1966 LWB Custom Cab (sold)
1982 Short Fleet (under the knife)
1998 S10 2wd Fleet
2007 Chevy Silverado Crew
2007 Harley Davidson Street Glide
badblu97 is offline   Reply With Quote
Old 05-28-2011, 11:28 PM   #5
shortbed70
shortbed70's Avatar
I would suggest an aluminum waterpump and radiator and get a set of heads with the cooling holes and you should be fine. My buddy runs a 414 and it will run 185 all day running down the drag strip. Ive thought about building one if I could find one for nothing. Try to find a 509 block.
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 05-29-2011, 10:26 AM   #6
Rich 5150 69
Rich 5150 69's Avatar
I`ve found the biggest issue is timing, people not having the timing dialed in on 400`s or 350 `s for that matter, my coupe runs a 406 and early fuelies heads, just an electric fan up front, no room for mechanical, it runs at 180 on the road, slightly higher if I get caught in traffic about 200..[IMG][/IMG]
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 05-29-2011, 06:37 PM   #7
bama63
bama63's Avatar
i have ran them on the local dirt tracks in all stroke combination's from 352s to 434s and have had no problems,just like any engine a good clean cooling system and adequate air flow and you wont have any problems as for drilling the steam holes in the heads if you are in a lot of heavy traffic then yes if you mostly drive freeway then no i personally have used them both ways and saw very little difference in temps with only a slight 10 degree increase if idling for a long periods and you also cant go beyond .040 overbore unless the casting is perfect when sonic tested
Due to financial constraints, the light at the end of the tunnel will be shut off until further notice
bama63 is offline   Reply With Quote
Old 05-29-2011, 06:45 PM   #8
jchav62
1962 C-10
jchav62's Avatar
I run a 400 in my 73 with a big block radiator. Never gets past 180. Awesome power. Very fun
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 05-29-2011, 07:35 PM   #9
chevyrestoguy
chevyrestoguy's Avatar
I love them. The whole notion about them overheating is an old wive's tale. There are few differences in the blocks, however. The -511 blocks are the 4-bolt blocks, and believe it or not, they are the weakest of the bunch. They still make a great street engine, but if you're really stepping on them with nitrous, they have a limit (over 500 horsepower) where they can become a problem. The -509 and -817 blocks are the 2-bolt blocks and they are the desired block, especially if you have them drilled for the aftermarket splayed main caps. I wouldn't suggest anything over a .040 overbore because of the siamesed bores, and also because the 400 blocks are notorious for core shift.
Build it, you'll love it.
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 05-29-2011, 09:34 PM   #10
Twiztid_66c10
i had a 400 sbc in my 51 chevy coupe and loved it ran the stock 51 chevy raditor with it and never any problems. the thing ran storng and great tell i hooked up 100 shot of nitrous and blew #7 rod
1966 C-10 long wide- currently with 2 3/4 sectioned crossmember, 3 inch cupped a arms with 2700 bags, 67 master cylinder, in the middle of a v8 swap,
soon custom rear wishbone set up and bags
1942 chevy/divco ambulance
1937 chevy truck
Twiztid_66c10 is offline   Reply With Quote
Old 05-29-2011, 10:34 PM   #11
78 Chevyrado
400's only have overheating problems is you use the wrong heads on them. as long as the steam holes are in the head, they're just fine.
78 Chevyrado is offline   Reply With Quote
Old 05-29-2011, 10:43 PM   #12
chainsaw
chainsaw's Avatar
Thanks for the info guys. The only 400 I had back in the day ended up having 2 cracked heads. Not the engines fault, but have been wary of them since.
