Where does this wire at the starter go?
I've been messing with my truck, doing a tranny swap. I knocked a green wire (that looks like it fits a flat blade) off, and I don't know where it goes. There don't appear to be any flat blades at my starter....and the truck won't start
I jumped the battery cable and the solenoid terminal, and the truck starts right up. The truck is a 250 straight six, '78. Anybody know where this goes? Did i bust a flat blade off somewhere? The tranny swap is from 3ott to a t-5...the trans part was smooth, fits like a glove...but I was also attempting to go to a hydraulic clutch...that's been a disaster. EDIT...excuse the crappy pics... Last edited by lilpoindexter; 05-28-2011 at 10:40 PM. Reason: crappy pics |
![]() Join Date: Jul 2010
Re: Where does this wire at the starter go?
That looks like tha oil preasure plug
1981 C-10 (Pop's) 1978 Camaro 2006 Lacrosse |
You welcome fam...tha T5 swap is my want list.good luck
Anyone else got an idea? In the pic above you can see the oil pressure switch, with three fat wires going to it?
![]() Join Date: Sep 2003
green.....temp sender if i recall
driver side on the side of the motor. its a temp sensor
You changed from a 3 on the tree to a T5 and now it wont start? What did you do for the neutral safety switch?
I kept the same pedal...I have the neutral switch pulled out all the way, but I'm going to jump the switch in a few minutes, because I'm thinking like you, that somehow i messed up the switch.
Thanks RatRod....I jumped the switch, and SHAZAMM...My rigged up hydraulic pedal doesn't "stroke" enough to close the switch.
