Old 05-29-2011, 09:51 AM   #1
iceship
Keeping it simple
My first truck..... 87 silverado. What is the EZ way..... It may not be the best way but what is the EZ to flipping my rear without a kit... I have been looking on there for days now... but no one has the step by step how to...... or I just missed it....
iceship is offline   Reply With Quote
Old 05-29-2011, 09:57 AM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Keeping it simple
If you want to lower the rear in the most cost effective manner go with a shackle kit and relocate your stock spring hanger. The shackle is very inexpensive but might require you to notch your bed cross brake. You can remove the rivets in the stock spring hanger and move it up. You will need to trim the top some, and drill new holes but this combo will give you about 4" of drop on a small budget.
Up front you can cut one full coil off your stock spring for approximately 2" of drop that won't adversely affect your ride.
The only problem with this mild drop is it will leave you wanting more...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 05-29-2011, 10:12 AM   #3
SCOTI
SCOTI's Avatar
The best way is the easiest way..... buy a pre-engineered, bolt-on flip-kit & keep it simple. If that's not cheap enough, build it yourself. If you don't have the tools, knowledge, or resources to build your own, refer back to my initial suggestion.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-31-2011, 10:21 PM   #4
Mikewb
do you guys just move the hanger up two inches and use bolts to put it back on? and how muchdo you have to trim off?
Mikewb is offline   Reply With Quote
Old 06-01-2011, 08:59 AM   #5
N2TRUX
Happy to be here
N2TRUX's Avatar
I have never done the stock hanger relocation mod. I do know that you gain about 2" and you will have to drill new holes and bolt it back on. I have read that the stock Burb hanger is shorter so there is no trimming required.
Articles-
"Refining Sierra"
