Old 05-29-2011, 05:39 PM   #1
snyder66
Shoulder Belts
How difficult is it to have them installed? Thanks
snyder66 is offline   Reply With Quote
Old 05-29-2011, 06:26 PM   #2
tucsonjwt
Re: Shoulder Belts
If you have all of the proper threaded holes already in your cab it should be no problem at all. If you have to make threaded holes - I don't know how you would do that.
tucsonjwt is offline   Reply With Quote
Old 05-30-2011, 08:37 AM   #3
str8axle55
Re: Shoulder Belts
A little more info would help. You could put a threaded plate in or cut a section from a donor truck.
03 GMC Yukon XL 2500 Quadrasteer, wife`s DD
84 Chevy K30 CC SRW
55 Chevy 210 2dr post
str8axle55 is offline   Reply With Quote
Old 05-30-2011, 10:30 AM   #4
mbgmike
Re: Shoulder Belts
I don't recall ever seeing a truck these years w/o the hole already there. But maybe never paid that much attention. if you don't have one you could always cut a hole,fab or buy a backing plate and use a expandable brass nut insert. Should hold it. You can use a fish wire to pull it up. Run a bolt through the plate and coil some wire up like a spring and thread it onto the bolt and ust it to pull up. You could tack the plate in remove the bolt then install the insert. But you should have a hole already
mbgmike is offline   Reply With Quote
Old 05-30-2011, 10:37 AM   #5
snyder66
Re: Shoulder Belts
Do you know what years they started having shoulder belts?
Old 05-30-2011, 10:43 AM   #6
mbgmike
Re: Shoulder Belts
don't get me to lyin but the 71 or 72's had plugs for the belts. I think California State required them before the rest of us and gm new they were coming. I know 77 had them. Look behind the trim panel. there should be a hole for them. the panel won't. I bet you will find it there
Old 05-30-2011, 10:56 AM   #7
snyder66
Re: Shoulder Belts
I don't own one yet, I'm just trying to figure it out. I wouldn't be comfortable driving without one.
Old 05-30-2011, 11:02 AM   #8
mbgmike
Re: Shoulder Belts
I would not worry, you can put a shoulder belt it just about anything these days if you have a roof.
Old 05-30-2011, 11:06 AM   #9
snyder66
Re: Shoulder Belts
Man! I wish I would have known that yesterday. Didn't bid on a sweet 79 Sierra yesterday because of it. The search continues...
Old 05-30-2011, 11:27 AM   #10
RandyP
Getting Old; Going Broke
RandyP's Avatar
Re: Shoulder Belts
79 should have shoulder belts already unless someone removed them.
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
Old 05-30-2011, 11:28 AM   #11
mbgmike
Re: Shoulder Belts
yes they started about 77
Old 05-30-2011, 02:26 PM   #12
Jonboy
Slots go on anything!
Re: Shoulder Belts
My '74 had lap belts, but had the shoulder belt upper nuts capped off. I am pretty sure shoulder belts have been an option from '73 up, but weren't standard until a couple of years later.
1974 Jimmy- 5.3/4L80e/NP241
Old 05-30-2011, 06:14 PM   #13
mrhino
Re: Shoulder Belts
I in the middle of putting, 03 Tahoe seats in my wifes crew. next i will be tackling the seat belts right now I have the stock lap belts but will be adding shoulder belts sometime this week. the front already has shoulder belts. but the back has a plug. after popping out the plug. I discovered just a hole. I planned on welding a nut to a plate. Then drilling a hand full of 1/4 inch holes in the c/piller. Fish the nut and plate up to the seatbelt hole and then rosset welding the plate to the c/piller. Then grind the welds down and make it ready for paint. At least that is the plan
mrhino is offline   Reply With Quote
Old 05-30-2011, 08:15 PM   #14
TheWhiteElephant
God is good!
TheWhiteElephant's Avatar
Re: Shoulder Belts
Here is a helpful link with a lot of pictures...
http://www.julianos.com/how2_3point74chevy.html
Mando
"It takes a smart man to know when he's stupid." -- Barney Rubble
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=430367
TheWhiteElephant is offline   Reply With Quote
