05-29-2011, 05:53 PM | #1 |
would this rim fit?
would this rim fit on a 72 2wd? I just need some temp rims that are larger than 15" and found a set of these for fairly cheap. I am using belltech 3" drop spindles and airbags (if that matters) and the 15's are rubbing the control arm.
http://vancouver.en.craigslist.ca/rd...406793582.html
1992 Gmc 2wd 1972 Chevy Blazer 2wd Last edited by 72gmcshorty; 05-29-2011 at 05:53 PM. |
05-29-2011, 06:21 PM | #2 |
Re: would this rim fit?
That's a single wheel and tire.
Posted via Mobile Device |
05-29-2011, 06:53 PM | #3 |
it's an example of the set i found....
1992 Gmc 2wd 1972 Chevy Blazer 2wd Last edited by 72gmcshorty; 05-29-2011 at 06:54 PM. |
05-29-2011, 06:59 PM | #4 |
I had read that again and noticed that lol. They are all backspace, I'd just measure a little before you buy. Measure the center hole dia. and if you can get away with that backspace but I don't see why not. I'm running a 7in plus backspace on my 72 rearend and 72 front swap parts.
05-29-2011, 07:03 PM | #5 |
Also, it could be cheaper running a spacer up front. I had 3in spindles and 15x6 and used a spacer and longer studs and it didn't rub anymore. I also have bags so they came in contact in more than a set height.
