05-29-2011, 09:12 PM | #1 |
Slight detonation still after overheat?
1969 with a 350 overheated today i heard the detonation before i saw the guage. After i let it cool and filled it up with coolant and changed the exhaust gasket that i think was the culprit it still detonates a little under load. any suggestions. No detonation before overheat.
05-29-2011, 09:37 PM | #2 |
laying low
Re: Slight detonation still after overheat?
Find the reason for the overheat and correct it. Check timing. A blown exhaust gasket isn't the cause of overheating. Bad thermostat will.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
05-29-2011, 09:40 PM | #3 |
~Rest In Peace~
check the inside of your distributor for condensation from the overheating ,could be cross firing from the water/
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
05-29-2011, 10:43 PM | #4 |
the exhaust leak was not a small one. loading and unloading from the trailer high centered and pushed the header around a little. the gasket fixed the overheating but slight detonation ONLY under load. wouldn't cross firing happen at any rpm load or no load?
