Old 03-30-2003, 06:45 PM   #1
toms68cst
toms68cst's Avatar
What is this clip for?
I'm assembling my motor and I have two of these clips on hand.
There are two other similar clips that I have that are for the front spark plug wires. They have some thick black insulation on them.
I think these two clips were on oil pan cover bolts too. The only other thing I can think of that might run down there was the positive battery cable that runs to the starter on the right side of the motor. The wierd thing is the mounting holes for these mystery clips are larger like they should go on one of the larger corner bolts of the oil pan cover.
Does anyone recognize this clip?
Thanks, Tom
Unrestored 68 C-10 CST. Original 327. 4-Speed CH465. 50k or so miles.
TREASURER, Drum Brake Club.
toms68cst is offline   Reply With Quote
Old 03-30-2003, 06:57 PM   #2
special70gmc
special70gmc's Avatar
they look like the vacume ine holder for a q-jet carb they bolt to the valve covers i belive. verry well cold be wrong though. -kyle
1986 c-10 swb 5/7 drop 20'' coys
1958 belair 2door
special70gmc is offline   Reply With Quote
Old 03-30-2003, 06:57 PM   #3
casey
casey's Avatar
can't see the pick real well but I think they look like the clips that attach to the oil pan and hold the transmission lines that go to the radiator
casey is offline   Reply With Quote
Old 03-30-2003, 07:08 PM   #4
racedvl
racedvl's Avatar
I belive there is clips that go along the oil pan that also hold the postive battery cable.
racedvl is offline   Reply With Quote
Old 03-30-2003, 07:38 PM   #5
Gee_Emm
I vote for oil pan batt. cable too :p
Gee_Emm is offline   Reply With Quote
Old 03-30-2003, 08:05 PM   #6
racedvl
racedvl's Avatar
Wwhhhooooo!!! I love it when I'm right!!! Or at lest when people think I am. . . .LOL
Old 03-30-2003, 08:13 PM   #7
toms68cst
toms68cst's Avatar
It's a 4 speed so there are no transmission lines.
Anyone else with an original sb that can verify where these go?
Old 03-30-2003, 08:17 PM   #8
Gee_Emm
Do you have a shop manual or factory assembly manual, try looking in there to see if you can spot it.
Old 03-30-2003, 08:19 PM   #9
bpmcgee
bpmcgee's Avatar
Tom,
My 1974 350 had brackets just like that on the old pan bolts on the passenger side. If my memory serves, they were holding the starter wires.
Brian
bpmcgee is offline   Reply With Quote
Old 03-31-2003, 12:09 AM   #10
toms68cst
toms68cst's Avatar
Thanks everyone. I have them installed on the rt side for the battery cable.
Old 03-31-2003, 12:37 AM   #11
Hooter
My other Love
Hooter's Avatar
Im 100% sure it's for the + battery cable, kinda important, keeps the wire away from frame and hot exhaust, it's always cool when the wire welds itself, or melts a hole through the exhaust.
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
Old 03-31-2003, 12:42 AM   #12
krue
Designated A-hole!
krue's Avatar
My vote is for the battery cable to the starter too. Comes in handy when your starter bolts fall out and the cable is the only thing keeping the starter from taking out the family in the car behind you.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 03-31-2003, 09:31 AM   #13
7T1BURB
The bracket/clip shown in your picture is, in fact, located on the oil pan...there are two clips on each side of the oil pan secured by the smaller oil pan attaching bolts....the one pictured is a FRONT (and non insulated) clip and attaches to the second from the front smaller oil pan bolt..the REAR clip(s) are larger (and insulated) and are attached to the second from the rear small oil pan bolt on each side....these clips are used to assist in routing the spark plug wires below the rams horn exhaust manifolds and rearward...interesting to note is that the routing of cylinders 1 & 3 (and 2 & 4) spark plug wires with the correct 90 degree spark plug boots is between the front motor mounts and the block...hope this helps...
7T1BURB is offline   Reply With Quote
Old 03-31-2003, 02:15 PM   #14
Long Knight
Spank 'em if you got 'em!
Long Knight's Avatar
So that's what those are for! I had some left over from my rebuild and didn't know where they went. So, I used them to hold up and extension cord in my garage. I guess I can see them working on my engine also.
Long Knight
'71 C-20, 350ci, TH350, Edl. 1406 Carb w/elec.choke, Ignitor ignition, Viper Tires, Orange Dipstick
Long Knight is offline   Reply With Quote
