Old 05-30-2011, 05:09 AM   #1
cr34t3d_by_d4rkd3n
3inch spindles on 15in rim IMPUT NEEDED
Hello, i have 15in alum flower mags and soon plan to plant them with a set of JDM 3in drop spindles.....
Is it true you must grind the lower arms in order for them to fit!? please say it isnt so.
If it is true? How much did you have to take off and where?? Pics would be great!
Pics attached are just some showing off at a j/y score
THANKS!!
EDIT: and no those stock bushings are not going to be used.....ever.
cr34t3d_by_d4rkd3n is offline   Reply With Quote
Old 05-30-2011, 05:30 AM   #2
piecesparts
Parts and more parts
piecesparts's Avatar
Re: 3inch spindles on 15in rim IMPUT NEEDED
It depends on the backspacing that you have on the rims. I have some rims that I purchased from WELD that had plenty of offset and the rims cleared the arms without any grinding. I also have rims that I had to grind the outer edge of the lower are off to get the clearance that I needed.
Frank
piecesparts is offline   Reply With Quote
Old 05-30-2011, 05:34 AM   #3
cr34t3d_by_d4rkd3n
Im not sure of the backspacing, but as the truck sits stock, the arms clear the rotors by a hair,...... hummmm........ craaaaaappp
Old 05-30-2011, 06:22 AM   #4
one low c10
I have the djm 3 in spindles with stock 8 in rallies and I only had to grind the new spindle. The very top of the spindle lightly rubbed the inside of the wheel, but the lower control arm wasnt an issue. I also have one coil cut from the springs too but wouldnt think that would make a difference. Just my .02
one low c10 is offline   Reply With Quote
Old 05-30-2011, 08:28 AM   #5
Restrorob
The One And Only !!!
Restrorob's Avatar
This is the area where most wheel interference occurs, A little grinding on the lips both front and back should solve the issue.
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 05-30-2011, 01:00 PM   #6
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
be aware that that lip gives the arm strength... I cant remeber how much I grinded off to get my wheels to fit... needless to say after about 3 months, the arm failed right at the ball joint (up and down motion kept bending the arm since there is no reinforcement..) and when it broke, it put the wheel in the fender and the truck in a gardrail on the freeway... so be smart about how much you grind off.
clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 05-30-2011, 04:12 PM   #7
GMC Guy
GMC Guy's Avatar
clint
x2! same happened to me, except i caught it before some catastrophic occurred.
Greg
1974 GMC
1/2 Ton SWB Fleetside
L33 5.3/4l65e
.................__
............._____l __\__
..............l_(O)_ l___(O)]
GMC Guy is offline   Reply With Quote
Old 05-30-2011, 05:49 PM   #8
GVazquez
GVazquez's Avatar
just put a 1/4" spacer on it problem solved.../thread
GVazquez is offline   Reply With Quote
Old 05-30-2011, 07:39 PM   #9
1LowToy
Had to grind in mine more than I liked for the 15-8 rally wheel. As I recall the daisy mags don't have much back space and the lip on the edge of the wheel is thicker than mine.
I ground off quite a bit then I changed springs away from the half coil I cut off to some new stock ones. Then heated and treated those to 5/8" shorter. I think its about 3.5" drop and it may settle for a little more breaking in. Unlike most I'll never waste time with cutting springs again.
1LowToy is offline   Reply With Quote
Old 05-30-2011, 08:25 PM   #10
lolife99
67-72 parts collector,…
lolife99's Avatar
clint
I've been trimming a-arms for 25+ years.
Never had one fail.
Keith
Convert to disc brakes.
Old 05-30-2011, 08:50 PM   #11
cr34t3d_by_d4rkd3n
top of the spindle you say?? where exactly? top of the "C" ??
Perfect illustration! What do you think? Will that effect strength to an unsafe matter?
clint
Your kidding!? dud im sorry to hear that, how much metal did you remove??
WOW!! now im kinda nervous.
See thats what i thought, will that really work?
Never had one fail.
See thats what i thought too, whats the most metal have u removed???
THANKS EVERYONE !!
Old 05-30-2011, 09:07 PM   #12
lolife99
lolife99's Avatar
This is one of my trimmed a-arms.
(directly below the blue tape)
This is enough to clear a 15" wheel with 4" backspacing.
It doesn't take much.
Trim,... then set the truck on the ground,... turn wheels left and right,... cycle suspension up and down.
Test drive.
Remove wheels and recheck everything.
Keith
Old 05-30-2011, 09:10 PM   #13
lolife99
lolife99's Avatar
This is the lip that I remove,...
Keith
Old 05-30-2011, 09:17 PM   #14
cr34t3d_by_d4rkd3n
Test drive.
Thats alot of steel!! and never one failure??
Old 05-30-2011, 09:22 PM   #15
Restrorob
Restrorob's Avatar
He still has the upper bend for support, What he took off was just hanging around for the ride....
93 Jeep XJ
88 Buick La Sabra
Toys;
97 GMC Ext. Cab
Old 05-30-2011, 09:25 PM   #16
lolife99
lolife99's Avatar
nope.
The blue tape was used to highlight where I did the trimming on the lower edge.
Keith
Old 05-30-2011, 09:27 PM   #17
lolife99
lolife99's Avatar
What's the backspace on your wheels?
You might not have to trim anything.
Keith
Old 05-30-2011, 10:15 PM   #18
3r!c84
Badass
3r!c84's Avatar
i had to take the grinder to these places when i did my 3inch spindles on my stock 15x8 rallies
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 05-30-2011, 10:54 PM   #19
N2TRUX
Happy to be here
N2TRUX's Avatar
Never had one fail.
I have done several sets with out any failure too. With that said, I also had a buddy that trimmed a set and they failed. From that point on I started boxing the bottom of mine.
The safest solution to this issue is run a 18" or bigger wheel.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 05-31-2011, 12:36 AM   #20
SCOTI
SCOTI's Avatar
Doesn't matter as far as trimming the a-arm lip. It just makes contact in a different location. The 18x8 TT2's I had w/5.25"bs required me to trim the a-arms on my 74 farther back than what I had to for the 15" ralleys before them.
I've also trimmed the lip on multiple trucks w/o experiencing any failures. I feel 3 key points to focus on are:
1) Avoid removing any material from the vertical portion of the arm. The vertical height is where the BJ area benefits the most for strength.
2) Drill a hole in the lip where I plan to terminate the area being trimmed (to minimize stress cracks).
3) No jagged edges. No perpendicular cuts. Everything needs to have smooth transitions (again, to minimize places for stress related cracks to form).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-31-2011, 08:22 AM   #21
N2TRUX
Happy to be here
N2TRUX's Avatar
I guess the answer is go with 20's then. I had 18's on my Blazer, but I was running trimmed and boxed arms. After that all I have had are 20's or bigger and no more issues..
Articles-
"Refining Sierra"
Old 05-31-2011, 10:44 AM   #22
boatpuller
boatpuller's Avatar
wished i knew the back space of my 17's.they clear with ease.i couldn't run the stock rally's,they rubbed bad....sounds like to me,it's all in the back space.
" Never look up a dead dogs butt."
boatpuller is offline   Reply With Quote
Old 05-31-2011, 12:05 PM   #23
lolife99
lolife99's Avatar
Correct!
Keith
Old 05-31-2011, 05:35 PM   #24
85gmcguy
Plays with trucks
85gmcguy's Avatar
[QUOTE=N2TRUX;4709157]I have done several sets with out any failure too. With that said, I also had a buddy that trimmed a set and they failed. From that point on I started boxing the bottom of mine.
Same here.
Gary
My Dad's Old Truck
1985
85gmcguy is offline   Reply With Quote
Old 05-31-2011, 09:50 PM   #25
1LowToy
Anyone have some pics of the boxed lower control arms. I trimmed mine too but I really don't like the idea without some reinforcement.
Note: The 3" spindle and 1/2 of a coil cut off was a bit to low with the 8" rally wheel /255-60 tire. It also due to the geomety made the lower control arm closer to the wheel and I had to trim more off of the lower control arm.
