Old 05-30-2011, 10:59 AM   #1
OlBlue85
OlBlue85's Avatar
Broken outer axel on dana 44
The outer axel on my 84 chev 4x4 snapped inhalf I know it has the dana 44 upfront but i guess there is a couple different ones you can put in how do I figure out what one I need if it helps it has autolockers on it
OlBlue85 is offline   Reply With Quote
Old 05-30-2011, 04:22 PM   #2
BigRed76
BigRed76's Avatar
Re: Broken outer axel on dana 44
There is a 1/2 ton Dana 44 and a 3/4 ton Dana 44. 1/2 tons are 6 bolt axles while the 3/4 tons are 8 bolt axles. I believe thats the only difference.
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Old 05-30-2011, 09:28 PM   #3
sierra4x4
sierra4x4's Avatar
Your truck should have a 10 bolt front diff not a Dana 44 but it could have been changed at one time. From what I've seen Dana 44 both 6 and 8 lug versions as well as all 10 bolts both 6 and 8 lug use the same stub shafts. So finding a replacement will be easy.
sierra4x4 is offline   Reply With Quote
