Old 05-30-2011, 12:15 PM   #1
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Lower control arm swap from 61 to 64-65
Im planning on baggin the front of my 61. My lower ball joints are shot so they need to be replaced and they are at least $120 each.
Question here is, can I use LCA's from a truck with out tortion suspension and keep my stock spindles?
This is a low buck project, so used LCA's are fine and i know the lower ball joints are cheap too.
Thanks for the help!!!
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 05-30-2011, 02:53 PM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Lower control arm swap from 61 to 64-65
Good question! My knowledge gets a bit foggy on the early 60's trucks with torsion bar suspension. I know the early trucks frames, rear axles etc were a bit different. Maybe we can get a 60-66 expert in here to lay it down correctly for you.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 05-30-2011, 04:02 PM   #3
61_FL_Apache
Who Me?
Would something like this work?
http://cgi.ebay.com/ebaymotors/Chevy...item1e6396eba0
Steve
2001 Blazer 4D 2WD
Old 05-31-2011, 09:56 AM   #4
Tony@AirRideTech
Junior Member
Not 100% positive here but... pretty sure you would have to change the whole crossmember out to a 63+.
Tony@AirRideTech is offline   Reply With Quote
Old 05-31-2011, 04:19 PM   #5
61_FL_Apache
Who Me?
I dont want to get that carried away.
Steve
2001 Blazer 4D 2WD
Old 05-31-2011, 05:27 PM   #6
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
LMC has different part numbers for them so logic would assume they are different. I would think they would be smaller since the 60-62 frames are wider than 63-64.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
