05-30-2011, 03:30 PM | #1 |
What caliper do I have?! Have #.
I've had the brake line off and showed parts stores and Oreillys for one isn't educated on many things. I need to know what I have so I have brakes to enjoy the truck. I can't drive until I get hoses and calipers. I originally had a hose pinched at a tire shop, they made a mistake and when I aired out and back up I had no brakes. I never found a hose so I blocked one side off and had one front brake. The trucks parked but since I need a hose I'll do calipers and better lines to the calipers. I ran several years and everything parts stores have brought out with a lot different. I have one off, by the way large wheels make it easier since I can pull them with the wheel on lol.
Caliper says this on the front like I typed. DELCO 6471 MORAINE 172 Posted via Mobile Device |
05-30-2011, 06:03 PM | #2 |
Re: What caliper do I have?! Have #.
I can take a pic if needed, if it gets this thing rolling. Need a idea of what I have or what I need to buy. I have 73-87 3in Belltech spindles and ECE 6lug conversion rotors. Can I buy 73-87 brakes, hoses, and calipers?
05-30-2011, 09:22 PM | #3 |
Yes, buy the brake parts for the year range on the spindles. 73-87 spindles = 73-87 rotors, calipers, & brake hoses. The only difference in your case is the rotors are ECE's 6-lug conversion rotor.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 05-30-2011 at 09:23 PM. |
05-30-2011, 09:30 PM | #4 | |
05-30-2011, 09:36 PM | #5 | |
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 05-30-2011 at 09:37 PM. |
05-30-2011, 09:39 PM | #6 |
low n' slo
i used 73+ rotors pads and calipers on mine too. the passenger side hose bolts right to the original hard line. the driver side should need an adapter fitting to make them work. i ordered mine from speedway motors. the hoses are a little longer but work, you will also have to drill a hole on the upper control arm to bolt the hose bracket to. let me see if i can find the thread where i posted the fitting size on..
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
05-30-2011, 09:44 PM | #7 |
low n' slo
its called an inverted flare adapter..heres the size
3/8-24 IFM, 7/16-24 IFF heres the thread i had started on this..
05-30-2011, 10:13 PM | #8 |
Well, I'll get my brakes, pads, and calipers asap. Sucks we have to order the little fitting. Thanks a lot for the help guys! The fitting size also helped bunches! $5.99 plus $9 shipping! High but o well, guess I'll only need it once for this truck lol.
05-30-2011, 10:17 PM | #9 |
low n' slo
lol, ya..at least you get a "free" catalog lol
a few people told me they got that fitting a napa, but i didnt have any luck.
05-30-2011, 10:26 PM | #10 |
There's a Napa a couple blocks from my house so it's worth a shot but they aren't the smartest there lol. I'm in no real hurry, the truck just sits in my garage lol.
06-01-2011, 12:02 PM | #11 |
Update: Napa couldn't find that adapter. I did take a caliper down there(drivers side), and it showed to be 87-88 1/2 ton Chevy. The hose also showed 3/8, so if these are correct to the hard line and the calipers correct then I have the new calipers already and hopefully I won't need that special order 3/8-7/16 adapter. If so I'll have the right parts tomorrow to do my brakes.
06-06-2011, 12:17 PM | #12 |
'78 C-10 hoses and calipers were all direct bolt on to my '67. I don't need the fitting.
06-06-2011, 12:30 PM | #13 |
low n' slo
hmm, thats odd. are both your hard lines the same size thread? mine were different, thats how i knew i would need an adapter on the driver side.
06-06-2011, 01:38 PM | #14 |
It was a frame off 15 years ago, guess it was changed then.
06-06-2011, 02:45 PM | #15 |
low n' slo
ya, must have been, well thats good. save ya 15 bucks lol
