03-30-2003, 08:23 PM | #1 |
Designated A-hole!
Is there a gasket for fenders?
Is there a gasket to go between fenders and bed on a stepside?
I just pulled some toolboxes off of it and looks like remains of a gasket. If there is, where can I get a pair?
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
03-30-2003, 08:32 PM | #2 |
There is "gasketing", and its called fender welting. It works well. Try the vendors on the board, they should be able to get a pair for you if you want them. Fender welting is not expensive, less than $15/pr.
JIm |
03-30-2003, 10:34 PM | #3 |
Designated A-hole!
In the interests of time can I skip it for now and use it later (after paint job)?
03-31-2003, 08:50 AM | #4 |
I painted mine first, glued the welts in place using 3M adhesive, burned the holes out with a soldering iron, and applied sealant to the welting before bolting the fender up. The joint is water tight!
Jim |
