05-31-2011, 10:13 AM | #1 |
How to tilt my Bench Seat
On my 69 C10 Base Vynil Bench, does this seat tilt forward to get behind it at all? It is locked now and I cant find any levers or buttons. Slides for and aft but cant tilt the back forward that I can see.
05-31-2011, 10:42 AM | #2 |
The Older Generation
Re: How to tilt my Bench Seat
There are two bolts that go through the metal brackets and into the part of the seat you sit on. I think the rear bolt can be removed to make the non-tilts tilt. The upholstery has to be modified to make this work. There is no usable space back there and with just a lap belt I would think it would be detrimental in an accident to have it tilt forward.... Just my 2¢ worth. LockDoc
05-31-2011, 12:14 PM | #3 |
Moderator
if it doesnt tilt now, it is. a fixed back i believe. the ones that tilt did so easily when the lever was pulled
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
05-31-2011, 03:48 PM | #4 |
Junior Member
67 and some 68 had the tilt back seat with a lever on the driver's side to release the seat back.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
05-31-2011, 06:15 PM | #5 |
My seat is a 68. There is no lever to make it tilt forward. You simply grab the seatback and tilt it forward. It does take just a little bit of effort though. Sometimes I have to push it back and then tilt it forward.
I think LockDoc is correct though about removing some bolt to make em tilt forward. Good luck. |
05-31-2011, 07:34 PM | #6 |
My 67 has wing nuts that have to be removed to tilt the seat.
Brad 67 Chevy SWB stepside - http://67-72chevytrucks.com/vboard/s...d.php?t=449426 89 Ford Bronco 92 Suzuki Sidekick 94 Kawasaki Vulcan 750 06 Honda Aquatrax |
05-31-2011, 07:38 PM | #7 |
there is one on each side. here's a pic and circled in red the area.
