Old 05-31-2011, 10:27 AM   #1
wutnxt
Location: vancouver b.c....is the biggest place most people would know but I am actually out in the valley 45 mins away
454 power steering brackets and pump
I have decided to add power steering to my pro street truck, now i have done the swap a couple of times with small blocks and it has worked out great. This time around I am running a 454 that is mounted with a front plate and runs a electric water pump. So The bracket set up I looked at had the steering mounted up high off the water pump and block. This set up isn't going to work at all....So what are my options with out things getting crazy? I am already over budget on this project but with all the upgrades and cash into this thing it seems silly not to have it .......So is there a quick easy bracket swap ?
1966 Pro street build http://67-72chevytrucks.com/vboard/s...?t=448089[
1958 LS 2 build http://67-72chevytrucks.com/vboard/s...d.php?t=527123
1966 SBFS low and go http://67-72chevytrucks.com/vboard/s....php?p=5799909
1966 SBFS street HULK http://67-72chevytrucks.com/vboard/s...=1#post5886625
Poject Low and go gets a 6.2 ltr LSA supercharged with 6 speed automatic
Aluinum Radiator Dealer pm for details
wutnxt is offline   Reply With Quote
Old 05-31-2011, 02:51 PM   #2
steverino66
Re: 454 power steering brackets and pump
Mine doesn't have electric water pump, but my steering pump has reservoir attached so I got a custom bracket here (they may have what you need?):
http://www.alangrovecomponents.com/Catalog.htm
steverino66 is offline   Reply With Quote
