05-31-2011, 11:43 AM | #1 |
need good pictures of high hump floor hole
i am needing some good pics of the trans tunnel floor hole on a high hump truck . i am cutting the floor and would like it to be correct . thanks
05-31-2011, 11:46 AM | #2 |
Re: need good pictures of high hump floor hole
You need pics of one installed or out of the truck. I would not cut the hole untill I had a High hump in your hands to go by.
72 Cheyenne Super 80 Silverado Blazer 2wd |
05-31-2011, 11:49 AM | #3 |
thanks i have a cover and there are a few indentations to follow and would like this to look original , the pics need to be with cover off please
05-31-2011, 11:50 AM | #4 |
Never mind , I see you need pics of the hole itself.
05-31-2011, 12:08 PM | #5 |
These pics are not that good but maybe they will be a start.
If you want it to look original, I guess you mean from the under side? There are going to be 2 Maybe 3 reinforcement strips that run along the the underside of the cab that the nust are welded to.
05-31-2011, 04:05 PM | #6 |
thanks for the reply , i was not aware of the reinforcement plates and could use some if you have or could supply . the hole shots are great can you get a little closer and show me a view of the area just below the heater - trying to figure out how much they removed - the factory has a rib that flows around the hole and im trying to duplicate the factory . thanks for all the help
05-31-2011, 04:16 PM | #7 |
Six in a row makes it go...
Top and bottom:
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086 66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790 CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224 “The height of sophistication is simplicity." - Clare Boothe Luce |
05-31-2011, 04:27 PM | #8 |
excellent can you get closer to the hole and show me just how far off the mounting holes the hole was cut - there is a pattern in the floor and im trying to figure the stamp and where exactly the cut was . and has your floor got the reinforcement nut like an oil pan or are ther nuts just spotted on with heat . thanks and sorry to ask for all this assistance on such a small detail but i can see your going to great lengths on the body and washing and removing all the tar . thanks
05-31-2011, 05:52 PM | #9 |
OK - I'm only doing this because I always have a good time in Canada when I visit.
I did the best I could. The cab is jammed in the back corner of the barn now - those other pictures were taken a while ago. The square nuts are welded to a metal strip and then that's spot welded to the floor (best I could tell). In other locations they are welded directly to the floor. Like my new storage rack?
05-31-2011, 05:55 PM | #10 |
just excellent , glad to hear you enjoy your visits , and appreciate the going over and obove - i can see the upturn on the metal and the distance . thanks
05-31-2011, 06:00 PM | #11 |
and the storage rack which one the gold one or the green one with the coffee
05-31-2011, 06:02 PM | #12 |
The green one - the coffee cans have C20 parts in them.
05-31-2011, 06:47 PM | #13 |
1969 Custom 30 wrecker
Nice rack!
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
05-31-2011, 06:50 PM | #14 |
I can honestly say that no one's said that to me before.
