Old 05-31-2011, 12:39 PM   #1
84 400
Sb 400 club
84 400's Avatar
Exclamation Sm465 Swap Questions 1977 K10 short bed
Well I was out fourwheeling Sunday and my th350 took a crap. IT sucked had to get the truck towed 70 miles home. I am done with automatics!
I have a 3 day run coming up this weekend and would like to make it but have a lot of work ahead of me. I have been reading up on this swap for quite some time but still need some adivece and a few questions answered.
Parts I have:
All cast Iron SM465 out of a 1977.
Hydro clutch bell housing
Hydro Clutch Fork
Hydro clutch pedal set up
Adapter to np205
!0 spline coupler
10 spline input shaft for my Np205
Flywheel
Still Need
Clutch ,
Pressure plate
Throw out bearing
Piolt bushing
Master
Slave
Line
Reverse light wiring
Questions:
Will a Hydro set up work with a 3 finger clutch set up or does it need a diaphragm style clutch?
Does this use a pilot bushing or bearing? I am firmilar with the bushings but have never dealt with the bearing style.
A flywheel uses different bolts to connect to the crank shaft then a flex plate correct?
I don't have gaskets for the adapter between the Trans and T case. Should I attempt to cut some from gasket paper or just use RTV?
Thanks For any help you can provide!
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
Old 05-31-2011, 01:06 PM   #2
Redcap
Re: Sm465 Swap Questions 1977 K10 short bed
Parts I have:
Hydro Clutch Fork
Adapter to np205
!0 spline coupler
Flywheel
Still Need
Clutch ,
Pressure plate
Throw out bearing
Piolt bushing
Master
Slave
Line
Questions:
Juice clutch will work fine with a 3-finger. I dislike diaphram clutches in general.
Definitely use a bushing. Less moving parts = less to go wrong. I have chewed the input shaft up on more than one transmission with bearings that failed.
Not sure on the flywheel thing. I don't deal with autos if I can avoid it.
Personally, I'd cut a gasket...but you would probably be fine with a thick coat of RTV.
Redcap is offline   Reply With Quote
Old 05-31-2011, 05:37 PM   #3
dutchmanz
Knuckle Buster, Instructor
dutchmanz's Avatar
Flywheel bolts are longer. Take the time to get a good set of ARP's or at the very least a grade 8 bolt. x2 on the bushing, bearings never seem to hold up long, although many still swear by the bearing.
Current classic fleet:
72 K5 Blazer CST, unrestored factory Orange paint...mostly
69 C10 factory SWB, 454, TH400, Saddle tan, Rust-o-ration
53 Studebaker M35 w/331 Reo gas I-6, Air Force Strata Blue
dutchmanz is offline   Reply With Quote
Old 05-31-2011, 09:02 PM   #4
84 400
Sb 400 club
84 400's Avatar
what throw out bearing should i use? One for a 78 or an 86 blazer with the hydro clutch , Does it even matter.
I will use a bushing never liked the idea of a roller bearing
Does anyone know what size bolts go from the adapter to the back of the transmission?
1985 C10 LWB Sold
Old 06-02-2011, 02:36 AM   #5
84 400
Sb 400 club
84 400's Avatar
Got a flywheel from a 78
Got a 12 inch clutch from a 78
got a 3 finger presure plate from a 78
Got the master, slave, line, T?O bearing and piot bearin for a 86 K5
Benn reading diffrent thing online... will a 73 3 finger pressure plate set up for a 12 inch clutch work with the stock 86 and up hydro set up? heard some say it rubs? Some say it work fine
1985 C10 LWB Sold
Old 06-02-2011, 09:31 AM   #6
dutchmanz
dutchmanz's Avatar
I'd say use the T/O bearing from the 86. I have no idea on the clutch.
Old 06-02-2011, 11:50 AM   #7
Redcap
Nevermind. I'd use the throwout from the 86 too.
Old 06-04-2011, 05:21 PM   #8
84 400
Sb 400 club
84 400's Avatar
yeah well after reading on CK5.com I found out a brog and beck AKA a 3 finger clutch will not work with the Hydrollic clutch fort because it will come in contact with the pressure plate. the 3 finger pressure plate is about 1 inch taller then the diaprham style.
I am gonna do a write up on this swap because there is just too much mis- information out there. It is going fairly well aside from the small changes in the firewall from 77 to 86. I will post up a link to the write up when i do it.
1985 C10 LWB Sold
