Old 05-31-2011, 04:26 PM   #1
ncgamedog
72/68 trans x-member question
I am looking for a trans x-member for my project and need to be sure I'm looking for the right thing. I'm using a 68 body and th400 mated to a np205 which is going onto a 72 frame . Can I use my factory 68 2wd x-member? Or will a 4wd x-member from a 72 blazer be the right thing to use? I found a 4wd x-member from a 72 blazer, but it had a th350. Will this still work since I'm using the 400?? Thanks for any help!
ncgamedog is offline   Reply With Quote
Old 06-01-2011, 07:10 AM   #2
ncgamedog
Re: 72/68 trans x-member question
Surely someone knows the answer to this on here...
Maybe I should clarify:
Will a transmission crossmember from a 72 blazer equipped with a th350/205 work in a 72 PU equipped with a TH400/205 without major modification?
Old 06-01-2011, 08:37 PM   #3
Chevy1TonFun
Grease Monkey
Chevy1TonFun's Avatar
You need to use a 4wd crossmember. The one out of the blazer should be the same as the one out of the p/u. The only difference between to two frames are the wheelbase.
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax
Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053
Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs
FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12
Chevy1TonFun is offline   Reply With Quote
Old 06-01-2011, 09:55 PM   #4
jamie72
jamie72's Avatar
use the 4x4,but just remember these trucks didn`t come from factory with a th400(in a 4x4),so you still might need to modify a little.. good luck..
jamie72
72 BB cheyenne -- Restoration getting started..
member #807
http://www.myspace.com/whitetailobsession
www.antlertalk.com
jamie72 is offline   Reply With Quote
Old 06-01-2011, 11:28 PM   #5
ncgamedog
ok thanks guys!
That is really strange to me too. Why would GM not offer the th400 in a 4x4? And whats even stranger to me is why they would offer it in a 68 2wd 1/2 ton with a 327ci. I could understand it in a 3/4 ton (c/k 20) or behind a bigger engine.
The 68 2wd has the 327 and th400. The trans is in great shape so I figured why not try to use it.
