Old 05-31-2011, 06:00 PM   #1
425HP409
425hp409
425HP409's Avatar
Question 72 disc Brakes on a 66 C10
I am installing 72 disc brakes and spindles from a 72 onto a 66 but have run into a ball joint fitment problem. What ball joints, it any, can I install in the 66 control arms and use the 72 spindles?
Charles
68 SWB, Dad bought new, now 396 & factory ac
64 Impala SS, 409 425HP, 4 speed AC
64 Bel Air Wagon, 400 Small Block
57 Bel Air all original 283 w/Factory Air
77 GMC Sprint, 454/425HP
67 Olds 442, all original
90 ZR1 Corvette
425HP409 is offline   Reply With Quote
Old 05-31-2011, 08:30 PM   #2
Chevy Fleetside
Chevy Fleetside's Avatar
Re: 72 disc Brakes on a 66 C10
I think the 72 ball joints work in the 66 arms.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is online now   Reply With Quote
Old 06-01-2011, 01:09 AM   #3
Captainfab
60-66 Nut
If the '66 is a C10, the '72 ball joints should fit no problem. If the '66 is a C20, then you have a problem. I don't know if there is a lower ball joint that will fit the LCA and the spindle at the same time. if it is a C20, have you tried the '66 ball joint? A '73-'87 C20 ball joint, The '88-'98 light duty 2500 ball joint? If worse comes to worse, you might have to go with a ball joint that is too big for the spindle, and have the taper on the spindle enlarged with the proper reamer.
Old 06-01-2011, 05:58 AM   #4
lolife99
67-72 parts collector,…
lolife99's Avatar
Outer tie rod will be different also.
More info here:
http://67-72chevytrucks.com/vboard/s...57&postcount=3
Keith
Convert to disc brakes.
Old 06-01-2011, 11:20 AM   #5
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
I have installed the 72 c10 discs on my 65, didnt have an issue other than outer tye rods like said.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
